The JDM lower pulley is here
Old Jul 11, 2001 | 03:43 PM
  #61
Spiro99SVT's Avatar
wow...I would bet that .1 of an inch if worth over 50+ degrees in Tepm increase..LOL j/k of course...for those that dont know me
c'mon guys...how much can this be covered??
Old Jul 11, 2001 | 04:42 PM
  #62
Hugh Jorgan's Avatar
Old Jul 11, 2001 | 04:57 PM
  #63
BfB's Avatar
BfB
Banned For Rules Violations
Originally posted by CornerCarver
BfB, shouldn't the difference be .05 not .5.
DANGIT! LOL! I fixed it yet again
So can we assume that the PSP pulley will lead to a higher air temperature than the JDM? Wonder if this is why JDM reduced his from 8 to 7.8?
Well, .1 isn't going to be much difference heat wise probably. I believe it should be probably be between 6 to 8 degrees maybe since JDM's first #'s were 22 degrees with the 8" and only 9 degrees with the 7.8" (his outer measurements would have been 8.1 and 7.9, though).
Originally posted by Spiro99SVT
OUR PULLEY IS TECHNICALLY 7.9 inches
Okay, that clear's it up, THANKS Spiro, bud
I'm rethinking my position on the pulleys again after researching and giving it some good hard thought. Forget everything I said previously and measure from the top of the grooves. Why? Because you know for a fact the belt contacts the highest point as evidenced by wear, and it is a relative measurement...all things being equal the ratio should be the same as long as you are consistent throughout, so to be accurate stick to a point you know the belt contacts on both pulleys. Most pulleys are engineered so that the grooves in them are deeper than the ones in the belt for that same reason of contact area I just gave, otherwise the belt would stand up off the pulley, and you would prone to massives amount of belt slip.
All in all PSP is doing the best of the two measurements, which is the TOP of the grooves.
BfB
