12 SEC Excursion! Yeh right
Old May 23, 2001 | 12:25 AM
MRBBQMAN's Avatar
Thumbs up
They probably used the good grade of diesel, instead of the cheap stuff, or something
Old May 23, 2001 | 08:10 AM
Mondo1's Avatar
Post
Lightningquick brings up a good point.How much did the suv really weight.BTW your right about the tq. figures with 400 h.p., the tq on that was probably closer to 675 lb/ft.
Old May 23, 2001 | 09:35 AM
LSchicago's Avatar
Post
The MPH is way off, but the 1/4 mile time is possible. There's a Dodge with a Cummins 5.9 that runs 11's with 600HP & 1200# torque. Diesels tend to run about 2-3 times torque vs. HP. This Excursion probably has at least 800-900 ft.#. Hypermax claims 500HP & 1000 ft.# on their Excursion. My 225 HP Cummins has 520 ft.# of torque, at 1600 rpm! max rpm on mine is 2700. A 500-600 HP semi engine puts out 1600-1850 ft.# STOCK! If you took a built powerstroke or Cummins, & installed it in a Lightning, Traction would be a thing of the past. Lloyd
2000 Black L Airaid & Superchip R9. Drag Results: Best ET: 13.07 Best MPH 103.09 Best R/T .501 (twice) Best 60' 1.631 on F1's. Mods to come: JDM 90MM MAF, JDM 2# lower pulley, JDM Oval TB, JDM Line mod valve, JDM Flip chip steet/race, PSP Electric fan kit, M/T ET streets, Drive shaft loop. I thought I could be happy with a chip & filter, but NO! 1973 Cutlass Supreme 455/450HP 4 speed. Too many Mods to list! 95 Olds Aurora 91 S10 305TPI/700r4 project 2000 freightliner FL60 Rollback tow truck My garage overuneth.
MODERATOR OR ROAD KILL AT www.svtperformance.com
