NEW: Idea For More Boost!
Old May 14, 2001 | 04:37 PM
rscoleman's Avatar
Post NEW: Idea For More Boost!
Maybe this has been suggested.....
Some of my buddies who have blown late model f-bodies have seen an increase in boost by replacing rubber/plastic intake ducting with metal pieces.
Using that theory, wouldn't a solid aluminized tube connecting the t-body to the maf be worth a pound or two of boost? If it were built correctly this seems logical to me. I know the eaton's operate at almost max efficiency, but this would not spin the blower any faster.
Am I way off.....or would this be worth looking in to?
Old May 14, 2001 | 05:31 PM
RTKILLA's Avatar
Post
I know someone made a pipe like that and they where talking about selling them, but I don't think that would give you nearly 1lb of boost. nothing at all in my opinion. the mustang guys switch over to a larger pipe most likely that can suck more air then the smaller plastic one's provided. thats the reason they get more boost most likely. I highly doubt that by have a metal pipe you'll pick up that much boost. Maybe, and just maybe .05 pounds.
Powered By: POWER SURGE PERFORMANCE Products.
www.powersurgeperformance.net/ubb/cgi-bin/ultimatebb.cgi
[This message has been edited by RTKILLA (edited 05-14-2001).]
Old May 14, 2001 | 07:30 PM
Road Rash's Avatar
Post
there is no boost till AFTER the blower.
Mike
Old May 14, 2001 | 08:20 PM
NOSTROMO
Guest
Posts: n/a
Post
The only way i could see that benefiting is if the rubber boot hose collapses under vacuum into the supercharger.
Old May 14, 2001 | 08:32 PM
Flintstone's Avatar
Post
BaBolt was making power tube haven't seen
any results
others opinion metal heat conductor
rubber insulator
waiting for results from BaBolt
Old May 14, 2001 | 08:58 PM
99svtlightning's Avatar
Post
It helps more with the centrifigul blowers because the boosted pressure is sent through the intake tube.
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
Old May 15, 2001 | 02:11 AM
Mondo1's Avatar
Post
"there is no boost until after the blower" Technically, that is true BUT,what people fail to realize is that a blower is naturally aspirated,yes that is what I said...naturally aspirated.It, like a nat asp engine does suck in air and is more efficient when the path of air BEFORE it is smother and or larger(the straw theory).Therefor what ever you can do to either smooth out that path of air WILL increase the boost ie: larger air filter and contoured,smoothed intake tube and even extrude honing the lower intake manifold.All of these will increase the boost of the S/C WITHOUT any adverse affects to the rotors of the Eaton. This is why I prefer doing this over the lower pulley.In a few words ...Boost with blower longevity.IMHO.
Old May 15, 2001 | 08:14 AM
Post
I agree with the straw theory to a certain extent. However, if you have a straw the size of a 4inch pipe and if you could fit your mouth around it, there wouldn't be a restriction. I can't prove the theory, nor will I try.
Therefore, if we were to remove the intake tube and somehow pull air directly into the throttle body I don't believe we would see a major gain in boost over a high flow filter and MAF.
Old May 15, 2001 | 08:26 AM
Big Poppa's Avatar
Post
Hello all..
Not to add any more to this debate.. but..
I remember somone saying that while running their L..( On the dyno ) they saw the rubber boot colapsing while under full boost.. I believe it was this observation that sparked the intrest in a solid intake pipe..
Got Boost ?
1999 SVT Lightning
Old May 15, 2001 | 08:47 AM
Mondo1's Avatar
Thumbs up
If you could bolt your maf directly onto your T.B., you would definitely see a gain in boost.And a solid pipe between those 2 components would show improvement.This is what they call "power pipes" in the Mustang world.The bigger the straw the better(in this case) Only ergonomics and space would limit the size, although any diameter larger than the T.B. would probably not net any significant improvements.I would kill for one of these power tubes for the L! Comon BaBolt.Do your thing!
Old May 15, 2001 | 09:54 AM
RTKILLA's Avatar
Post
You wouldn't want to put the mass air that close anyway. the farther away and outside of the vehicle, the better the reading from the MAF. I higly doubt that a rubber boot with any kind of good filter kit is going to collapse on us. that boot is pretty damn solid.
Old May 15, 2001 | 10:22 AM
Big Poppa's Avatar
Post
Hello all..
If I am not mistaken someone made a metal intake pipe out of a 4" mandrel bent 45 degree elbow.. They just shaped one end to an oval shape so it would fit the throttle body..
as for the boot colapsing..I think it is possible.. but it might not be..
Either way..a metal pipe would be a nice piece..
Got Boost ?
1999 SVT Lightning
Old May 15, 2001 | 06:43 PM
1RedDevil's Avatar
Thumbs up
How many people have taken off the rubber boot between the Throttle Body and the Mass Air? If you had you'd find HUGE RIBS that interupt the air flow, to a large extent, by cavatating the air being sucked in rather then a smooth piece that would greatly enhance the air flow passage.
Whether MORE Boost is achieved by a smoother air passage or not it certainly CAN'T HURT!!!
Just my 02.
I will be one of the first to but BaBolts new Power Pipe, when it becomes available,-If nothing more then to keep the F$$$ing oil from being trapped in those ribs from the pvc system!!
Dan
PSP TOTALLY MODIFIED
Best ET 12.57
Best MPH 107.89
Best 60 ft 1.72
So-Far!!
Man, I LOVE These PSP PRODUCTS!!!
(Thanks Sal!!!!)
Old May 15, 2001 | 08:11 PM
Bad as L's Avatar
Cool
Over a year ago when I first started reading this board, somebody said they where going to make and sell a Carbon Fiber intake pipe.
I havent seen it show up yet, but it would be the COOOOLEST. In more ways than one.
Dale
Old May 15, 2001 | 10:42 PM
BABolt's Avatar
Talking
I posted this photo over at the Corral(showing bends and transition tube). I just have to do a little fab work to get this ready for the Lightning. I have made inlet tubes for my Mustang and Ranger.
