lightning guys i need your help ASAP clutch fan!
Old Nov 17, 2007 | 12:37 AM
shifty_85's Avatar
Exclamation lightning guys i need your help ASAP clutch fan!
im in the process of taking my clutch fan out and....how do i get it out?? ive got a big wrench on the fan shaft and a wrech on the water pump bolts and nothing is working...any ideas? ive been trying for the past 3 hours to get this thing off!!...ive hit the vese grips on the fan shaft about 100 times it has 1/2 a bottle of WD40 on it and it still wont come off! or even move at all. The water pump bolts seem to just spin as if there not grabing thread any ideas on other ways to hold the pulley in place while i crank on the fan?? 1997 F-150 4.6L thanks guys!
Old Nov 17, 2007 | 09:20 AM
Rob_00Lightning's Avatar
Nevermind....
Old Nov 17, 2007 | 03:40 PM
shifty_85's Avatar
used a hammer and a big punch because i dont have an Air compress so i pretty much made a slower air hammer but it is normal threads on that fan Left=loose i just had to hit the egde of the fan shaft for like 5 mins and it started to come loose then i just spun the fan and it came right out
Old Nov 17, 2007 | 05:57 PM
Cialis's Avatar
Put a large screwdriver or tire iron in between two of the pulley bolts and then use a large crescent or pipe wrench to remove the fan.
Old Nov 17, 2007 | 06:20 PM
Glad you didnt listen to me
dam it's been a while since I took one off a L but I swore it was reverse
Old Nov 18, 2007 | 02:26 AM
shifty_85's Avatar
dont worry my buddy with a ranger swore when he took his apart it was reverse but me and one of my other friends didnt think so...should it have said that some were in the owners man.? i looked and didnt see anything about the fan...im sure i coulda found it online but it came off so i didnt look.
Old Nov 18, 2007 | 10:23 AM
built54's Avatar
considering the water pump pulley spins counter****wise looking at it from the front, it would have to be that way
wow why cant I say "c-lock?"
Old Nov 19, 2007 | 01:03 PM
Struck in AZ's Avatar
Judging by the number of '*' you forgot the 'L'...
