Help My Truck Won't Start!!
Old Mar 23, 2001 | 10:42 PM
HANKFAN's Avatar
Post Help My Truck Won't Start!!
I just got through installing JDM's throttle body, 90 mm mafs and JL's air kit. Now my truck won't start. It will run for a fews seconds then die. I have checked to make sure all the sensors are back in place. The only thing I have noticed is that I now have quite a bit of slack in the 2 cables that attach to the side of the throttle body, I would assume these are the throttle cables. Any ideas???
HANKFAN
Old Mar 23, 2001 | 10:49 PM
wrightlightning's Avatar
Post
Hankfan,
I had some "issues" with my Pro-M and my truck acted similar to what you are talking about. Mine would run if I gave it some gas. I would suggest checking to make sure the MAF is plugged up good. If so, replace your original to see if it will run. Did you get a chip burned for the MAF?
Good luck!
Black '00
#2216
Old Mar 24, 2001 | 12:00 AM
red gen 1 94's Avatar
Post
you dummy......you havent had your chip reburned.............wtf wrong with you...have that kitty on your mind and it has f#*@ed up your thinkin!
red 1994 lightning....oh my god i never expected this thing to keep running this long......130,000 miles and still running strong.........
00 white L...# 1993 build date 4/5/00 JL filter kit 2"drop shackles and JL flip chip billet third brakelight cover, water wetter, mobil 1........later it may get NOSty........
Old Mar 24, 2001 | 01:40 AM
HANKFAN's Avatar
Post
It had nothing to due with the chip, I found a hose under the rubber boot that was loose. It's fine now.
Brian
Old Mar 24, 2001 | 11:18 AM
Hilander's Avatar
Cool
Good work Hankfan, Let us know what you think of the new set up.
2000 Lightning Silver frost
Clear corners (Front only)
PSP Intake, JDM Chip, Bed Rug, Snuglid
Old Mar 24, 2001 | 01:30 PM
WhiteLightninSVTGirl's Avatar
Post
<~Kickin Red for being mean to Hank (cousins right??) Play nice hehe
CA
