Tranny fluid question?
Old Sep 4, 2007 | 05:13 PM
wgood's Avatar
Originally Posted by TrackBeast
Call them up and ask them if they approve it for our application.
Mobil ATF and Amsoil has been used for years in our transmissions. Some say with a 20 to 30 degree drop in temps. I never measure mine before and after.
I did e-mail Royal Purple about thier syn. ATF. When I bought my L the previous owner was running it. They assured me it was compatible with our trucks. (Kept the e-mail )
Old Sep 4, 2007 | 05:21 PM
SWThomas's Avatar
I'm sure they're great fluids but if someone claims they reduce the fluid temps by 20-30 degrees, I'd have to call straight-up-B-to-the-S!!!!
Old Sep 4, 2007 | 06:28 PM
1sweetsvt's Avatar
x2.
Old Sep 4, 2007 | 10:47 PM
SVT F15O's Avatar
I was about to say the same thing......
Old Sep 5, 2007 | 12:06 AM
Tim Skelton's Avatar
Originally Posted by pitstain
. . . Do not worry you will always be able to buy dexronIII/Mercon spec fluid.....
"Effective July 1, the production and licensing for MERCON will cease."
You may be able to buy fluid that meets the spec, but the manufacturer won't be able to use the word "Mercon" (no "V") in its name.
Hence Valvoline's new "DEX/MERC" ploy, along with their statement that "Helps provide smooth shift performance where DEXRON®-III or a MERCON® fluid is specified."
Valvoline is skating on some mighty thin ice here. If I were its attorney, I would probably counsel it to lose the name and make sure that the reference to "Mercon" is in small letters on the back of the bottle.
The idea is that you can reference the spec, but you must do it in a way that does not suggest source, affiliation, or sponsorship.
Old Sep 5, 2007 | 12:18 AM
pitstain's Avatar
Thin ice or not man, where theres a market theres a way.....either way I am not worried about getting proper trans fluid 5 years from now, but you are 100% correct on the "thin ice" wording.....it's pretty damm normal these days and quite amusing to say the least
Old Dec 15, 2007 | 11:38 AM
RED 92's Avatar
use dexron III
http://i54.photobucket.com/albums/g9...rconVChart.gif
Old Dec 15, 2007 | 12:56 PM
DirtY_Dave's Avatar
Mobil 1 ATF....
Old Dec 15, 2007 | 03:41 PM
Originally Posted by RED 92
Dexron is not even mentioned in that chart.
Old Dec 15, 2007 | 05:18 PM
RED 92's Avatar
I dont see the connection to Dexron lll in this chart. Why are you giving misleading info you fool. Dexron is not even mentioned in that chart.
Your right its irrelevant since its no longer available along with Mercon. Dexron lll and Mercon is the same thing in reference to VM in the chart for the 4R100..... ATF that meets requirements of Mercon or Dexron lll or use Mercon V for the 4R100.
Ford and your manual has recommended Mercon V for all vehicles for the past seven or eight years, most Fords on the road continue to be serviced by Mercon/Dexron lll. Mercon V, however, is a far better product that more closely resembles the factory-fill ATF which Ford has used for over eight years says Ford. Any Lightning owners lose a tranny to that "dont use Mercon V"
General Motors announced it was closing the door on its Dexron III category, and planned to license only Dexron VI in the future. Its Dexron III licenses all will expire on Dec. 31, 2006. Like Mercon V, Dexron VI is a more robust and shear-stable product, and requires the use of Group II or II-plus base oils. The two are different enough in shift and friction characteristics, though, that GM’s move doomed the Dexron/Mercon confluence.
Old Sep 20, 2013 | 05:06 PM
1BADTK's Avatar
Just in case someone uses this post for reference, the Ford Owners Manual that comes with your Lightning says Mercon ATF for 4R100, and Mercon V for 4R70W, and it also says do not mix ATF with V. If your still not sure look at the dip stick, it is plainly marked on it, Mercon ATF.
Old Sep 20, 2013 | 06:25 PM
Your dipstick was made before Ford discontinued Mercon ATF.
What seems to be the problem with running Mercon V in a 4R100?
Old Sep 24, 2013 | 10:22 AM
TrackBeast's Avatar
11 years now with Amsoil ATF and still shifts like new. I would say the case if proven at this point.
