The "project" so far ...
Old Aug 23, 2007 | 12:39 PM
SVT_KY's Avatar
Originally Posted by LightningTuner
Yeah, I am not slinging anything.
Just making observations. Ken knows what he's doing.
I knew that ... < grin > Hey can you give me a call? I need to
know about the tunes on the 4way and how they will work on
the new setup.
Thanks,
Cliff
Old Aug 23, 2007 | 12:41 PM
SVT_KY's Avatar
Originally Posted by svtsilverback
glad to hear this cliff. i am first in line for a ride.
I need to have a ride in your beast, also ... That first night you got it done I was too busy dippin the wick. I wasn't ignoring you and Mel and Brian say it pulls like a tractor !!!
Old Aug 23, 2007 | 01:25 PM
svtsilverback's Avatar
i am re-installing my vacuum lines. i knew i had something wrong when it would not break the tires lose in 1st i pulled the whipple off last night and i am going to check my plugs before i put the s/c back on. sucks to pull the blower just to look at the plugs. hope to have it back on the road friday. if so i will swing by. plus i have had your impact gun in my cruiser for weeks now lol. i did not want to leave it on your porch. i will bring it back i promise. can not wait to see how your #s look compared to mine. long block vs whipple.
Old Aug 23, 2007 | 05:16 PM
MikeyP60's Avatar
Rebuild
Glad to see you're almost back. Mike
Old Aug 23, 2007 | 06:05 PM
Sharpshooter's Avatar
There's nothing wrong with using the Romeos, but he'll need different valve covers. Might be hard to add oil with the fill cap on the driver's side under the power steering bracket .
My fill cap is on the Passenger side; the neck is just a little shorter than on the stock Windsor covers.
Old Aug 23, 2007 | 06:50 PM
SVT_KY's Avatar
They come both ways ... You just have to order the right one
Latest ... the bolts for the front cover are different ... Another day ...
Old Aug 23, 2007 | 07:11 PM
LightningTuner's Avatar
Yes, Romeo heads use a smaller stud size.
Old Aug 23, 2007 | 08:05 PM
tallimeca's Avatar
yeah
Sal, it was magnaflux'ed and everything checked out. They call that a "casting mark" and there are several of them on the block. Scared the sheat outta me, though ... You guys got GREAT eyes !!!
Yeah, i wasn't busting *****, i was just honestly looks to see any marks on the rod bolts to see if they were new and was like ummm......
Funny thing, the same thing happend on the 408 i built for my old man's stang this winter. I AM NOT an engine builder and don't claim to be, but he took it apart and is a hack so i figured it was better me then him...haha. Had the whole rotating assembly together and flipped it to put the oil pan on, as i was putting the gasket on with the pins i was like ****!!! I thought it was a crack near the cam journal. Iwas was a casting mark thank god.
What are romeo heads? Are they the 2v 4.6 heads or something?
Old Aug 24, 2007 | 03:55 AM
Ricki F-150's Avatar
Your pulling the Whipple in order to check the plugs !
Why ??
Old Aug 24, 2007 | 06:09 AM
Rob_00Lightning's Avatar
Why ??
Because it sucks monkey a$$ to change plugs with a Whipple Ricki. And dont even try to tell me or him differant because I dont think there's another L brother thats changed more plugs on a L than me and the facts are it does suck.
Yes you can do it without touching the SC (I have) but the time wasted and fustration is &@$#*(!@#$(!@#%)@$%(@$%(@$&
Next time I'm taking the SC off too
Ahem ahem all Vendors:
WOULD SOMEONE PLEASE MAKE A 2 PIECE UPPER FOR THE WHIPPLE
BEST OF LUCK CLIFF looking Gooooooooooooood
Old Aug 24, 2007 | 07:30 AM
Hey Rob
Next time your down at Jim's shop ask those guys how to swap out the plugs.
Removing the Whipple takes a lot longer trying to undo those bolts under the body.
Easy to whip off the IAC valve to get #6 & #7 out.
Use the Snapon 7mm knuckle socket to remove the awkward cop bolts.
We cab debate this all day, I have tried both methods.
Anyway time for a dip in the pool
Old Aug 24, 2007 | 08:36 AM
the first reason i took the whipple off was to redo the vacuum lines. i am using JDM's racer kit sketch to run my lines. so the whipple had to come off.
Old Aug 24, 2007 | 05:12 PM
SVT_KY's Avatar
OK OK ... I need some Valve covers ... And I have searched for them all over....
Anyone have a good source? Are the BBK about the best?
TIA
Cliff
Old Aug 24, 2007 | 05:32 PM
TIA
Cliff
Cliff, do a search online for Team Breed Racing. He makes aluminum SOHC valve covers in all different configurations.
Old Aug 24, 2007 | 05:57 PM
Frank5L's Avatar
I have the oem covers with the oil fills in the correct place but I really can't tell you where they came from because I bought them off ebay.
