Throttle Body Installation Q....
Old Jul 28, 2007 | 11:58 AM
Bird's Avatar
Yep, one separator per side will work great, but a 1-way PCV valve is a lot cheaper than an extra oil separator and accomplishes the necessary function (although, the extra hardware does add a 'cool' factor).
Just gotta make sure that you get the proper 1-way valve, otherwise the PCV system wont work at all.
Bird
Old Jul 28, 2007 | 12:08 PM
Dbl G's Avatar
You have missed the Picture...., there is no need what so ever for one on the drivers side, period.Wither one chooses to run a check valve of sorts or not.
Good luck there.
Old Jul 28, 2007 | 12:58 PM
halflife's Avatar
Bird
do you have the part number for the pcv valve you are talking about?
Old Jul 28, 2007 | 02:12 PM
Bird's Avatar
Good luck there.
I've got the picture perfectly - whenever the vacuum in the inlet tube exceeds the vacuum in the crankcase, there will be oil vapors / residue drawn into the inlet tube from the driver's side valve cover (no built in separator). I've had great luck with the setup I'm running for over 15,000 miles - have you run your passenger side separator with just the factory setup on the driver's side?
Bird
Old Jul 28, 2007 | 03:40 PM
Dbl G's Avatar
Bird
Yes for the last year plus
