MM&FF Lightning
Old Nov 20, 2000 | 11:17 PM
PFA's Avatar
PFA
Talking MM&FF Lightning
Just for info......
The Jan. 2001 edition of MM&FF shows them putting on a full Bassani exhaust.
They did 4 base runs and turned out 360 HP and 419 lbs.-ft of torque, they had a Superchips chip and a Cervinis functional ram-air hood, useless to the dyno.
When they finished WITH THE EXHAUST, they did another dyno and came up with 373 HP and 445 lbs.-ft of torque (13 HP and 26 lbs. torque gain) FROM THE EXHAUST ALONE.
THE PRO-M COULD NOT BE USED BECAUSE OF THE RAM-AIR SETUP, AND USED THE ORIGINAL MAF.
SORRY FOR ANY CONFUSION..
[This message has been edited by PFA (edited 11-21-2000).]
Old Nov 20, 2000 | 11:55 PM
BadBolt's Avatar
Post
Was that a 00 or 01 L? I find it hard to believe the 360 rwhp on an 00. Don't most come out near 330 rwhp. The torque numbers seem high too. I wonder if they published the 'ole spike numbers for more mag sales. Maybe their L has got the super secret new Eaton sneaked under the hood.
Old Nov 21, 2000 | 12:17 AM
SilverBullet's Avatar
Post
I don't find 360 hp with a chip and air set-up, that far fetched, mine made 357hp and 430 lb-ft with an airaid and Inject-Tech chip.
P.S. it is a 99.
Old Nov 21, 2000 | 08:32 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Question
Interesting comment about their having to remove the Mass Air sensor because it didn't fit with the ram air setup. Their numbers seem a bit high also. They were attained without a MAF?, highly unlikely. Slicks and VHT on the dyno rollers maybe?
I like the headers with the exception of having to cut 1/2" of threaded material off the shock so it doesn't impale the header pipe. Anyone with these headers have to do the same? I think this would have been mentioned perviously.
At least they are giving our rides coverage.
Brake Late, Dive Deep
Speedin Bob
'99 'Red Rocket' Lightning #2504, 6/17/99
NLOC # 438
**detuned for winter**
times irrelevant
removal of chipenfilter, return to stock airbox, 17" Expy rims with Comp T/A tires (they were cheap ok) Winter dualers to follow.
Summer setup
13.56 @ 100.89, 1.97 60' on F-1's (still learning)
JL Ram Air, R9 Chip,Keyless Entry, Retrax Bed Cover, Shackles, Wet Okoles, Mobil 1/FilterMag, Clear Corners
Autophysics filter FOR SALE [9" x 3.5" Red Trim]
Old Nov 21, 2000 | 08:43 AM
bggroth's Avatar
Post
Speedin Bob,
I have installed the Bassani headers on two trucks and you only have to cut the top off the shock if you install the right hand header before the left one. The reason you cut that off is so when you tilt the engine to get the left header in, if the rh header is already installed the rh header will tilt with the engine and bind against the shock stud. What I did was, jacked the engine up, installed the left header, set it back down, reinstalled the motor mount bolt, and installed the right header. It worked fine, no cutting or grinding. Hope it helps.
Brian
99 red lightning, bassani complete system #1610 of 4000
2001 arctic cat zr440 snopro on the way
2000 super duty v10
Arctic cat 400 4x4
Cobra "R" #131 of 300
Moderator
www.svtperformance.com
Old Nov 21, 2000 | 05:19 PM
LightningDammitt's Avatar
Post
PFA-
No offense, but I find the wording of your post a little confusing....
The way I interpreted the article was that this is a project Lightning for MM&FF. The 360 HP was for a chip and filter unit similar to the PSP full meal deal, and a new mass air aka Pro-M.
The next month, they added the Cervini's Ram Air, which required going back to the orginal mass air. The original mass air, plus the additional filter area provided by the larger filters in the hood netted 13 hp on the dyno. (Better air flow)
Their comment about the ram air being useless on the dyno.... The ram air contributions cannot be measured on the dyno since the truck is not moving and forcing air into the hood and intake.... Sothey couldn't determine gains for the ram air on the dyno...
Old Nov 21, 2000 | 06:26 PM
PFA's Avatar
PFA
Post
Refined.....hopefully
Old Nov 21, 2000 | 10:46 PM
Post
Cool!
Old Nov 21, 2000 | 11:25 PM
JIGAWATT's Avatar
Cool
It sounds alot like the test that was done at Anderson Motorsports.
July 2000 Super Ford
(peak#'s)
Stock: 404 torque 346 HP
Pro-M and K&N: 401 torque 357 HP
Bassani's full kit added: 436 torque 370 HP
Old Nov 22, 2000 | 12:27 AM
BadBolt's Avatar
Post
Hey Brian
Did you get only one ZR440 this season. Which one did you get; and, what are the differences? Man, they are BEAUTIOUS!!
http://snowmobilenews.rivals.com/def...2&stid=8056364
Old Nov 22, 2000 | 08:37 AM
BLACKSUNSHINE's Avatar
Thumbs down
Old Nov 22, 2000 | 08:39 AM
Spiro99SVT's Avatar
Red face
I gained 35 h.p. and 50 lb. of torque with mine.....yea, that's it.... It's TRUE, It's TRUE
Spiro-"The Greek"
BLK. #1476
Best run to date
12.373 @110.15
Best 60` 1.76
@ 4800 lbs.
On Pump Fuel
_________________________
JDM Engineering- Ford Specialist
Johnny Lightning Performance
http://www.webtechnik.com/johnnylightning
"Empty Pockets Racing"Drag Race Team NJ-DE
Spiro99SVT@aol.com
LAUNCH HARD !!!
Old Nov 22, 2000 | 08:47 AM
bggroth's Avatar
Post
Badbolt,
Yea I'm only getting one new sled this year. The seconed sled never gets used much so I figured I would just make due with one. Talked to the dealer yesterday, figured it sould be here next week. We'll see.
Brian
2000 super duty v10
Arctic cat 400 4x4
Moderator
Old Nov 22, 2000 | 08:29 PM
Ryan2KRedL's Avatar
Question
Wow. I can't believe none of you remember that the exhaust was not STOCK. MM&FF did an article on installing a BORLA muffler and tailpipes just a couple of issues ago.
Guess those 360 horsepower figures were not a TRUE STOCK exhaust comparison!!!!!
Notice the very slick camera work in the January 2001 issue, they actually never show the muffler and tailpipes on the truck that are supposedly stock!! So how are you gonna believe the hp and torque figures???
Haha is all I got to say!!
Later and happy turkey day!!
Ryan
  • 2000 Red Lightning
  • 13.13 @ 106.40 mph in 1/4 mile
  • 8.50 @ 85.43 mph in 1/8 mile (same run)
  • Superchip R9, Airaid box with S+B 10" filter
Old Nov 22, 2000 | 11:26 PM
PFA's Avatar
PFA
Post
If I remember correctly, they did not gain any, or VERY little power from the other muffler they put on...???
