JBA Headers Install
Old Nov 19, 2000 | 12:26 AM
GOTECHS's Avatar
Question JBA Headers Install
Hi, Guys
I had the JBA Headers installed back in July and have not been able to go back to the shop to have the manifolds tightened.
Today, I noticed a really wierd ticking sound that increases in volume when the gas is pressed on. I was told that it was an "exhaust leakage".
Will it harm the truck if I continue to drive it since I will not be able to bring it in to the shop until next weekend.
Old Nov 19, 2000 | 02:41 AM
wrightlightning's Avatar
Smile
I am by no means an expert, but it sounds as if you have an exhaust leak. As long as it is not "too" bad/loud, you are not in any danger of hurting anything. However, there are few things less annoying than an exhaust leak.
You should be able to determine where it is coming from while it is idling and just tighten the header bolts yourself, if it is worrying or bothering you much.
Old Nov 19, 2000 | 08:04 PM
lightning2strikes's Avatar
Post
GOTECHS
It could burn out the gaskets or worse especially if it is on the heads and not the exhaust bisket. don't wait too long. it will get worse.
Old Nov 19, 2000 | 09:59 PM
GOTECHS's Avatar
Post
Thanks, Guys
I'm going in to the shop tomorrow.
Old Nov 20, 2000 | 09:05 AM
SVT-Snake's Avatar
Post
Gotechs,
After you had those installed did they make a big difference in power? sound? I am thinking of buying a set just wondering, thanks.
00 Black Lightning
No mods yet
00 Honda Civic
01 Pontiac Grand AM GT
Old Nov 20, 2000 | 06:06 PM
SVT-Snake's Avatar
Post
ttt
Old Nov 21, 2000 | 12:06 AM
GOTECHS's Avatar
Post
I don't think it was worth the money as I did not feel any big difference.
Put your money on a chip/filter combo. You'll definitely feel the power difference with this.
Old Nov 21, 2000 | 10:55 AM
Big Poppa's Avatar
Post
A friend of mine put a set of JBAs on his 99 L.. Now his header gasket is leaking.. Does anyone know of a good replacement that will not leak ? ( Other than a stock )
Much thanks..
Got Boost ?
1999 SVT Lightning
Old Nov 21, 2000 | 05:30 PM
HIGH ROLLER's Avatar
Cool
I have the JBA headers on my L and have had no problems yet!They are not worth the money i saw no gain in e.t.Leave the stock exhaust alone unless you want a deeper sound from a catback.But don't expect more power!If you want noticeable results in e.t buy a good quality chip a pro-m and ford throttle body with good sticky tires this combo will result in .8 to 1 second off your e.t time!
12.99
105.90
G-Tech
0-60 4.34
1/4 12.71
40 degree air
Old Nov 22, 2000 | 08:56 AM
BlueOvalBolt's Avatar
Post
Don't have headers on the L but when I put them on the Cobra, I had similar problems you all are experiencing. I highly recommend Stage 8 locking header bolts if they make something for the L's application, don't see any reason why they wouldn't. Once installed, you will never have to worry about them again.
'99 L, JL Stage II Ram Air, Bassani cat-pipes, Borla cat-back, R9 Superchip, Cal-Tracs, Chassis Tech 2" drop shackles, Water Wetter
'93 Cobra, 1 5/8" FMS shorty headers, 2 1/2" Mac cat-pipes, Borla cat-back, 180 degree thermostat, 4" ram air, 3.55 gears, March pulleys, strut tower brace, Kenne Bell flip chip, Crane Hi-6 ignition, Crane coil, Global West Trac-Link, Hurst chrome shifter, Canton oil pan, BFG g-force kd tires
[This message has been edited by BlueOvalBolt (edited 11-22-2000).]
Old Nov 23, 2000 | 12:43 AM
DJANIMATE's Avatar
Post
I was actually thinking about getting those, I've seen them advertised saying they give you a 17HP gain. What BS! Sounds like most of them don't even fit right. We should make a "Scam" thread and put them in there. Sorry about your misfortune but thanks for saving me some money.
Adam
1999 F250SD 4x4 PSD
black 2001 L ordered (is it February yet?)
