Towing question
Old Sep 26, 2000 | 09:48 PM
Moonshine's Avatar
Question Towing question
When hooking up the wiring to tow a small trailer (no trailer brakes) with a 4 pin connector is it necessary to install either of the relays into the fuse panel? Thanks in advance.
Old Sep 26, 2000 | 10:18 PM
Silver_2000's Avatar
Post
Duh Which relays ?
When I towed with my 92 that had same connector is was plug and go. Once the hitch scraped through the rust on the ball I had lights....
Doug
Old Sep 26, 2000 | 11:48 PM
Mister SVT's Avatar
Post
I am not sure either what relays you are referring to exactly, but I have towed my motorcycle trailer and boat several times and all I did was plug the adapter into the exsisting terminal and then pluged the 4way plug right into this; havent had a trouble to this date.
Eric
Old Sep 26, 2000 | 11:53 PM
thepawn's Avatar
Post
I think that kit is a leftover from 99 stuff, the relays were already in our 2000s that came with the hitch.
Old Sep 27, 2000 | 12:40 AM
blubye-u's Avatar
Post
Not necessary ,but is good idea.Relay will keep voltage spike from trailer from damaging
L elecirical system.My 2000 did not have relays installed, were in bag with trailer acc.Just my 2 cents.
2000 Silver L
A.R.E. LS II /w wing
Bedrug
Lojack
Clear Corner Lenses
Airaid w/10" Bigmouth Filter
Superchip R9
