KB 2.6 with stock block???
Sounds like a Plan, AND A DAM GOOD ONE
Richies runs a 3.7 (or is it 3.75) upper + 4lb lower and makes great power
Mine came with a 3.0 upper and I had a (well lets just say i run a "larger" lower pulley)
Over the weekend I plan to pull A LOT of Boost from it, as said I highly recommemd you do the same. DON'T WORRY YOU'LL STILL HAVE MASSIVE POWER
Originally Posted by SVTLIGHTING
Well, I talked it over with my tuner and he said that it is risky but he will do his best to give it a safe tune.( not too much boost). The way I see it is if I destroy the bottom end then ill have to build it anyhow. I am going to be purchasing it next week. Will not install or dyno it untill spring. That will give me plenty of time to order all the other goodies.....
If it is like most things, the price will only improve with time and any newer changes or happenings will be in place when you buy.
Just a thought...
i would
blow that 3900 on upgrading the short block and valve springs, then crank up your stock blower.
Then next year, upgrade the rest.
I dont' understand why people change blowers, pumps, maf, and run a stock block with stock heads, valve train. There are a lucky few, but if you aren't prepared to fix it when it breaks, then start from the ground up.
If i had 4k to spend, i'd do at least the lower end first, then do the rest. I upgraded my pumps just because i was gonna pull them to make sure my clamps weren't falling off.
I tried to upgrade the Maf........that's a whole other story.
Said F'it.
Spend the money on a lower end first. Then you can sell your stock short block and make a few bucks if it has such low miles on it.
Good luck at what ever you do.
Said F'it.
Originally Posted by Odin's Wrath
Anybody remember when a 2# pulley was pushing your luck?
but i do think we are capable of running a stock bottom truck into the 10's now
right
We've made strides in tuning and technology.
We know what these stock blocks can and can't handle.
Why put on a KB 2.6 is if you can't reap the benefiets of it.
Upgrade your motor first.
Would you build a second story on a sigle story house on a foundation that was crumbling?
Originally Posted by tallimeca
Right, and that was when no one knew anything about these lightnings and the 5.4 mod moters were fairly new to the aftermarket performance world.
Hide and watch.
There are guys finding out just what the stock block can take, instead of just theorizing and preaching about it. The new SCT MAFs have only been out for a year, and the Whipple less than that. Tunability is better now. Detonation is, and was, the enemy. I'm running a safer tune now than I ever have, and making more power by a long sight. The engine can take more than we previously thought. The transmission, however, did not make it.
Hide and watch.
Storm
Originally Posted by DSM Storm
Amen to that man. I wanted a lightning for a long time. I passed out on it becuase of people saying that it can barely handle a pulley upgrade. I had a 99 sherrod. Love it, that got totalled. I got my 01 lightning this may and havnt looked back. Im hopeing the 3.3L whipple makes its way out soon. Ill add that to my truck this summer and tune it to see what it can take. If the engine fails, then It will be time for a buildup.
Storm
Storm
Originally Posted by NCsvt2003L
People are going to soon realize that even built motors won't be able to handle a 2.6 KB or for that matter the boat supercharger 3.3 Whipple. Not that the block will blow up, but the amount of boost going in won't net any gains and probably will make less horsepower than a 2.3 KB or 2.3 Whipple would. That means major head work and cams matched to support the race chargers.
bigger lift on the cams is all you really need,,,,too much lift was always a problem with the little kb
the bigger kb and the whipple 2.3 can support bigger cams
