INTERCOOLER IDEA
Old Sep 12, 2000 | 02:36 PM
  #31
BABolt's Avatar
Talking
Hey Noel
I can't give you an estimate on that short of a length ( 12" = 1 foot). As for the bypass it is not in yet as my tank is still under construction. I can shoot a photo.
BABolt
SVT#290
Old Sep 12, 2000 | 03:53 PM
  #32
Y2KBLKLITNIN's Avatar
Post
Check this out,not cheap but interesting! http://www.thrasher-ep.com/L67_htm/new_cooler.htm
Old Sep 12, 2000 | 03:59 PM
  #33
Spiro99SVT's Avatar
Arrow
With the truck at normal operating temperature, I usually have a intercooler reading between 95-110 degrees. After just 4 minutes of cooling with the JohnnyL/Spiro "IGLOO COOLER" my temperature drops to a cool 60 degrees.
Now, if I were to cycle the fluid with a cold truck, the coolant has gone as low as 36 degrees But like stated by Babolt, you need to consider the vibration factor and volume.
Old Sep 12, 2000 | 04:30 PM
  #34
TimBurntire's Avatar
Question
Spiro,
I see you've got a water temp guage that measures below 100 degrees.
Can you tell us (Noel needs one too) what guage you bought?
Tim
Old Sep 12, 2000 | 04:39 PM
  #35
Spiro99SVT's Avatar
Arrow
I do not have a temperature guage that is permanently mounted, I use a kitchen thermomter that is extremely accurate. I take my readings with the intercooler reservoir cap off,with the temperature guage probing the coolant. I do plan to make this a permanent guage under the hood.
Its the ones with a small 1.5 inch face with a 6 inch probe....hope this helps
Old Sep 12, 2000 | 05:38 PM
  #36
noelvm's Avatar
Lightbulb
I got an AutoMeter 2 1/16 Water temp gauge today. It starts at 100. Now to Lowes to find a copper tee with a threaded base that matches one of the two pipe fittings supplied with the gauge. The inside diameter of the intercooler hose is 5/8", just measured.
noelvm
Old Sep 13, 2000 | 04:59 PM
  #37
noelvm's Avatar
Talking
Neither Lowes or Home Depot had a usable tee for this appication, nor the aeroquip catalog. The search continues tomorrow.
Old Sep 13, 2000 | 05:44 PM
  #38
PFA's Avatar
PFA
Post
It's not the prettiest, but you can use a galvenized pipe tee. I have have this gauge but it will only read 100*. I can't find anything wrong with it and it only reads 100* in near boiling water too.
Old Sep 13, 2000 | 05:52 PM
  #39
noelvm's Avatar
Post
Yea but that's really ugly. I have my reputation to consider. I can make one out of cooper fittings and sweat it together if I have to.
