Nitrous kits
Old Aug 29, 2000 | 02:27 PM
cobra99's Avatar
Post Nitrous kits
Does anyone make a lightning nitrous kit.. Which one did you go with? Please respond. Me and a few guys are looking into it. Your input is appreciated.
Old Aug 29, 2000 | 02:51 PM
noelvm's Avatar
Talking
Finally took my truck in for the intercooler replacement. I think they finally have all the parts. Took my trophys too. Told'em to be careful test driving it because there was a chip installed in it. The head mechanic say "Noel, please don't put nitruos on your truck, please don't put nitrous on your truck. I'm not gonna work on it if you put nitrous on your truck. I looked at him and smiled.
Did you check all the nitrous post in the NEW FAQ?
[This message has been edited by noelvm (edited 08-29-2000).]
Old Aug 29, 2000 | 04:14 PM
TampaBayLightning's Avatar
Post
Noelvm:
Nitrous is not yet installed?
Now I get it.. Thanks
Rich
1999.5 SVT Lightning - Red. Super Chip. K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, AIM 2" Drop, Trenz billet grills, Piaa 9007 Super Whites, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt...cs/SigPic1.jpg
2001 PT Cruiser - Limited Edition
1999.5 Expedition XLT
[This message has been edited by TampaBayLightning (edited 08-29-2000).]
Old Aug 29, 2000 | 04:26 PM
noelvm's Avatar
Talking
Not yet. He just figures since I've put on a MAF, filter, and a chip that nitrous is next.
Old Aug 29, 2000 | 04:38 PM
cobra99's Avatar
Post
yes I did read them all ..
Old Aug 29, 2000 | 04:53 PM
Lightning Boy's Avatar
Post
NOS, NX, Edelbrok(spell?) are all trying to come up with kits but have yet to see one. They are saying that the kit will come with 150 shots. But that is too much. 75, 100, or a 125 (pushing it) is what you need. People with Nitrous kits have moddifyed mustang 5.0 kits or custom kit. 1BADTK has a custom wet kit witha 75 shot, turning 12.3's. We are running a dry 100 shot kit from NOS that have only produced one 12 second run. This partually due tot he fast we have so much extra weight, and one of the weaker L's stock. We are about to convert to a wet system. If you are looking for Nitrous info check out the FAQ and this link: http://nloc.org/ubb/Forum7/HTML/000049.html
Tommy 'Lightning Boy' Shelton (son of the Wyldman)
mustang73@houston.rr.com
-1973 Mustang Sport Coupe (currently being resto-modded)
Old Aug 29, 2000 | 10:55 PM
Hitman31's Avatar
Question
Tommy,
I know this has been covered here before(call me lazy for not checking the faq) but how much n2o can these bad boyz really take,if any at all? How much of a danger does it pose,even in small doses?
What kindda of gain can one expect in 1/4 times w/ a chip/filter/and Nitrous working together?
I guess I just wanna know if it's worth the risk. So is it?
Hitman
Old Aug 29, 2000 | 11:47 PM
HANKFAN's Avatar
Post
I am also in the process of buying a nitrous kit for my L and have did a lot of research on adding nitrous. I have talked with all the manufactures and several Lightning owners in order to make the decision to add nitrous or not. I must say that after understanding more about nitrous I must say that it is 100% safe to run nitrous on our L's. Our motor is probably the strongest built factory motor ever. Since we have forged crank and pistons, the additional cylinder pressure will not harm our motors. The biggest shot that is recommend on our L's is 125hp shot(dry) 150(wet). What I have found out about nitrous is that most people who have problems with nitrous don't install it properly. Our trucks are unique in that they run so rich from the factory that we can install a 125hp (dry) shot of nitrous without having to upgrade the fuel system. The reason why most people hurt their motor with nitrous is because they end up leaning out their motor by not upgrading their fuel system. Almost all factory motors do not run rich enough to run nitrous without upgrading the fuel system. This why were are fortunate that are L's run rich.
I am going to purchase the 5115 kit from NOS. This is actually a kit for the EFI Mustang's but it will work on our L's. Also with this kit it is necessary to buy a Fuel pressure cut off switch( this is a safety device that cuts the nitrous off if the fuel pressure drops). Also a bottle heater is a must. This will keep the nitrous bottle at the correct psi for maximum flow. If your nitrous bottle gets to cold and you use it, it could possibly harm your engine. Also if you don't want to have to turn your bottle on manually you can get NOS's remote bottle opener. Finally you will need to buy several jets from NOS depending on which HP shot you decide to run. The 5115 kit comes with the 75 HP jet. Nos told me that this kit was making close to 100 hp on the L's do to the extra cooling effect the nitrous had on the supercharger. Hope this helps!
HANKFAN
Old Aug 30, 2000 | 12:12 AM
ralleyone's Avatar
Post
Hankfan,
thanks for all the info, I wasn't seriously considering nitrous until reading your post. What does the 5115 cost, including everything?
Thanks in advance.
Old Aug 30, 2000 | 12:19 AM
WA 2 FST's Avatar
Post
A cold nitrous bottle will not hurt the motor. I'm sorry, I have run this stuff for awhile now on my '96 Cobra, and have researched it for a long time. A cold bottle means nitrous pressure will be lower than normal. What this means, is that less nitrous will be injected and you'll actually just run a bit rich.
If the bottle pressure gets too HIGH, then you run the risk of a lean condition, or having a solenoid stick open.
FWIW, the 5115 kit costs ~$475 from Summit.
Wes Tarbox
90 LX 5.0 (10.69 @ 134.7)--597rwhp/590rwtq
96 Cobra (12.63 @ 114.5)--392rwhp/433rwtq
99 Lightning (13.20 @ 103.3)--364rwhp/444rwtq
00 Expedition XLT 5.4
http://members.aol.com/Wa2fst/index.html
Old Aug 30, 2000 | 08:29 AM
cobra99's Avatar
Post
Is the 5115 kit a wet or dry system....
Old Aug 30, 2000 | 08:50 AM
WA 2 FST's Avatar
Post
It's a dry kit. Realize that there is a 5115-1 (Stage 1) and 5115-2 (Stage 2) kit.
The difference is basically that in the -2 kit you get an inline fuel pump. This is necessary when bumping up the shot on a pretty stock Mustang (which is what this kit was originally designed for), but from what I've been told by several here, you do NOT need the inline pump when using it on an L. I guess we have a pretty big pump in the tank from the factory. Large injectors like we have are great, but are worthless if the fuel supply to them isn't there. I know the factory Mustang pumps are tiny, but like I said people are running the Stage 1 kit (which will save you ~$200) and then just buying seperate jets (which are cheap) to increase the nitrous shot.
I have plenty of data on recommended jetting from NOS, if you're interested.
Wes Tarbox
Old Aug 30, 2000 | 09:05 AM
FSUFAN's Avatar
Post
Ralleyone,
Matt Here. If you still doubt the nitrous application and are concerned about it hurting your engine, you should give Nitrous Oxide Systems (NOS) a call. Ask to speak to Lloyd. He is like their Ford “Freak”.
They have two trucks out in California that are using their systems and are acting in the capacity of like test trucks. One of the truck was using Sixty (60) bottles of nitrous a month. Yes 60 bottles a month. That’s 2 bottles a day. And they have had no problems at all!
Just a little note for thought.
The 5115 kit on my truck works excellent and I have had no problems at all. It is imperative to make sure you dyno your truck and get the air/fuel mixture a little on the rich side, and make sure it’s not running lean.
Good luck & Happy Spraying,
Matt
2000 Lightning, Chassis Tech Drop Kit, 80 mm Pro-M Mass Air, w/ K&N Filter, Danny Swanson Flip Chip, Flow Master 40 Series Exhaust, Billet Upper & Lower Grill, 100HP Nitrous Oxide NOS System. 12.533 @ 109.10 MPH
GO FLORIDA STATE SEMINOLES
Old Aug 30, 2000 | 10:10 AM
HANKFAN's Avatar
Post
FSUFAN, how long did it take you to install the kit? Was the wiring diffucult? Also did you ever dyno your L with the 75hp jet that comes with the kit?
Thanks, HANKFAN
Old Aug 30, 2000 | 02:05 PM
cobra99's Avatar
Question
Where did you mount the tank?
