Intercooler Pump
Old Oct 16, 2006 | 02:41 PM
tlfwatch's Avatar
Red face Intercooler Pump
OK here we go lightning only has 8500 miles on it intercooler pump shouldn't be out with no more miles on it than 8500 pump should be on with a 5 mile drive. I have not checked fuse yet not sure which one is the intercooler pump fuse i cannot see any fluid moving in the tank and do they make a more powerful pump.??????
Old Oct 16, 2006 | 05:37 PM
Mondo1's Avatar
Sometimes the connection on the pump itself is poor.Pull it out and blow it out and make sure it clicks in. I've fixed a couple of l's that way. Also , if you can hear or feel it running then you may have air cavitating in it. Then you need to "burp" it. Disconnect the outlet hose while its running for a few seconds. 8500 miles is way to soon for a pump to wear out under normal conditions.
Old Oct 17, 2006 | 01:05 PM
promodlightning's Avatar
If it is your ic pump, ebay has them for 80 bucks. New in the box.
Old Oct 17, 2006 | 03:18 PM
tlfwatch's Avatar
Ok Lightning Bros & Sis. Help Me With This One
Ok lightning friends i believe my pump may be working .I have bubbles and foam in inter- cooler tank what would would cause this cavation probley????? please post your thoughts thanks a million TOM
Old Oct 17, 2006 | 04:13 PM
Mondo1's Avatar
As George Sr. would say: Read my post!! Air could have gotten in ther a number of ways. None that are as relavent as the solution.....Burp it!!
Old Oct 17, 2006 | 04:49 PM
tlfwatch's Avatar
Talking Thanks I Will Burp It .
[QUOTE=Mondo1]As George Sr. would say: Read my post!! Air could have gotten in ther a number of ways. None that are as relavent as the solution.....Burp it!![/QUOTE
Thanks i will burp it first thing in the morning i didn.t think pump was out with 8500 miles on it thanks
Old Oct 17, 2006 | 05:55 PM
JollyGiant's Avatar
It is normal for the tank to have bubbles and turbulence due to the high flow rate of the pump.
Old Oct 18, 2006 | 12:03 AM
Slick_Sammy's Avatar
i cannot remember the exact conditions at which it should be running, but it is not supposed to run all the time. i dont' think it will run until you get up to a certain temp. just FYI. i thought mine was broke b/c there were some rumors spread that it runs all the time, which is not the case. and yes you're going to have a ton of swirling bubbles going on. not sure you need to burp it or if that is really even possible.
Old Oct 18, 2006 | 08:44 AM
rickgig's Avatar
The pump comes on in about 45 seconds after startup. I jacked with mine a coule of times when it started to fail. Junk accumulates inside the unit although at 8500 miles that should not be the case. A temporary fix is to hit the pump with a hammer (gentle but firm hit) and that will knock the crud off the inner walls.
It's a magnetic drive and when the junk get too thick it doesn't have enough power to keep spinnning. I cleaned mine twice and gave up and bought a new one.
Old Oct 18, 2006 | 05:59 PM
tlfwatch's Avatar
Ok Lightning Friends Flushed Inter-cooler
I flushed inter-cooler tank etc with water and refilled with fluid it had a little foam at top of tank before is foam normal looks clear now and pump is working good what gives ??????
Old Oct 18, 2006 | 06:13 PM
Suavy's Avatar
One thing that I do when I change engines or when I take my intake off is remove the inner cooler and take it to my local radiator shop. They boil it and pressures check it for leaks. The cost is around 50 bucks helps me with fluid flow, leaks and efficiency.
God Bless,
Suavy
Old Oct 18, 2006 | 07:40 PM
SWThomas's Avatar
Disassemble the pump and clean it.
Old Oct 18, 2006 | 10:14 PM
rickgig's Avatar
Just replace it...
Old Oct 18, 2006 | 10:19 PM
SWThomas's Avatar
Cleaning it is cheaper.
