Tuned-Daily-Drivers POLL
Old Feb 18, 2006 | 04:24 PM
  #31
sadf's Avatar
Originally Posted by Rio J
I need a typing class and you need a dictionary. You can also work on your ethics. Maybe you can get 2 for 1 at the bookstore.
Uhh... your lame
Old Feb 18, 2006 | 06:17 PM
  #32
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
03 HD, 60K miles, stock block, daily driver, tune modded at ~18K w/ Predator, 6# lower, stock HD upper, metco idler w/ 100mm pulleys, Factory Tech Valve body and tranny cooler, L&S oil seperator, C&L elbow and plenum, FRPP SBTB, JLP air kit, JLP traction bars, 2" shackles, Ruslow 1100 lb coils and panhard bar, QA1's, Magnaflow midpipes and L-spec catback.
Happy camper
Bob
Old Feb 18, 2006 | 07:41 PM
  #33
olefafl's Avatar
Over the last year I have gotten to this setup.
2# upper
Frankenplenum
K&N w/ fresh air hoses
Modified stock air box
TR6 plugs
FTVB
no tune
When the Predator Revision 8r10 was installed last week (91 octane pulley tune) it pinged. With a delta chip it runs fine.
Old Feb 18, 2006 | 10:00 PM
  #34
Jay Lincoln's Avatar
2lb lower, chip, ProM 80mm mass air; 118,000 miles
Still runs strong. Ran my best 1/8 mile times at 86,000 miles
Old Feb 18, 2006 | 10:56 PM
  #35
LTNBOLT's Avatar
2000 L stock engine with 68,000 miles.
I've been in the 400/500 club since 02.
Lots of mods.
I've been running a KB@16#'s of boost, 55 lb. injectors, SCT MAF for close to a year.
Last time it was dynoed with the pull stopped at 5200 rpm.
Old Feb 20, 2006 | 11:56 PM
  #36
chicosvt's Avatar
My mods are 6# lower, ported blower, tr6's, bassani catback, lfp H/E, drop in K&N, and a custom diablo tune. My corrected numbers as of 4 days ago are 424hp and 519 tq. I have about 6000 miles on the truck with that setup and a total of 26k on the odometer. I drive her every day all day long.
Old Feb 21, 2006 | 08:46 AM
  #37
Silver_2000's Avatar
My 2000 had over 83,000 miles on it when sold. about 65K of that with a 4# pulley, headers, filter, chip, line mod, efan, throttle body etc etc etc .
The only real problems I had with it was a few problems with old school caged pulleys, burned 2 spark plugs on a race gas tune that I wasnt told about and I went thru a few transmissions - Part my fault, part bad luck and likely partly due to excessive tranny changes in the tune..
Daily driver - used it to follow the FFW circuit 2 years in a row made 10 events one year and seven the next
I now have a 2004 with 4# pulley, SCT tune from Peformance Research , headers and exhaust. I have over 20k miles on it of daily driving. So combined I have driven the 2 Lightnings over 100k most of that with aftermarket tunes.
Old Feb 21, 2006 | 08:59 AM
  #38
yysenhimer's Avatar
Promoting a company with a link that is not a supporting vender? hmmm...
Old Feb 21, 2006 | 12:04 PM
  #39
Dan SS2471's Avatar
My '01 L had enough mods to put it at 440/538 to the wheels. It had 21,xxx trouble free miles when I sold it.
My '02 HD has a built block and KB and makes 525/634 @ 18 PSI and I put 11,000 miles on it from April to January of this year when I parked it. No troubles at all.
Old Feb 21, 2006 | 02:38 PM
  #40
HalfTime's Avatar
4lb lower, 2.80 upper, 90mm MAF, K&N, Duel Single cahber FlowMasters, Predator Tune. 73k miles. Daily driver, plus just got back from a round trip from FL, to NC, to WI and back down to NC.
