Would appreciate some advice - hopefully Tim Skelton could reply too
I've recently had a built motor done for my '02 L and have gone through the break in miles my builder recommended. I won't bore you with all the details about my experiences up to this point, but I do have a question concerning it.
I took my truck into a local speed shop for some dyno tuning. While on the dyno, the truck developed a loud internal knock. I had the truck hauled back to my engine builder who is in a different State to tear into it and examine what the problem was with it. My engine builder called me yesterday and told me that #7 & #8 cylinder pistons were melted and damaged the bottom of the head at the #8 spark plug along with various other problems that result from this type of damage. The motor obviously will require a complete rebuild. In your opinion, what would of happened to cause such damage?
Originally Posted by RustySocket
What was the A/F on the dyno run?
How many pulls did you do?
If the vehicle was run lean as an example (and only as an example), how long would it take to cause a melt down?
Sorry to hear about this news......
First ? - Do you trust this shop?
Second ? - Have you asked them for #7 and #8 cylinder heads? If no proceed to the twilight zone. If yes have a second opinion drawn.
I asked a local shop recently - If I bought a built block from you and she went boom what would you do? He told me that they would tear down the engine and determine the cause - if it was detonation (melting heads) then it would be blamed on tune conditions, not engine build.
Sounds like this shop (whether they are right or wrong) is leaning that way to remove themselves from responsibility. And they may be perfectly straight, but there are always two sides of the coin - and I would be demanding both sides.
Get a second opinion on the cause and cover all your bases regarding the tune - your dyno should give a few of the missing pces.
Good Luck!
D-Day
Good Luck!
D-Day
Originally Posted by Hostile03SVT
maybe the timing was too far advanced in your tune? just a thought..
Also, as an example, a 255 walbro pump fails at 3500 rpm, the tuner noticed immediately that the fuel pressure is at 34-35lbs. Would that cause this sort of damage?
Good Luck!
D-Day
Good Luck!
D-Day
Originally Posted by dirtchicken
No it wouldn't cause that much damage. It might fry a plug or two if they got out of it IMMEDIATELY. It sounds like they did multiple pulls on the dyno.
Originally Posted by l-menace
Race engines are generally caveat emptor
Caveat emptor. Latin for "let the buyer beware." It refers to the sale of something of value, without a warranty from the seller.
My issue is not with the engine builder at all, he's been fantastic all the way through this ordeal. My issue is with what happened to the motor on the dyno and what would have caused this sort of damage.
