Hungry for more valvespring info: Read this!
Old Jan 10, 2006 | 02:41 PM
  #106
fade 2 black's Avatar
Suspended for Cross Posting
If you can shim the springs without compromising coil bind then that will work. I'd rather just have a stiffer srping to begin with.
Old Jan 10, 2006 | 02:50 PM
  #107
Ruslow's Avatar
yes it will work BUT springs are designed to have this psi at this height and if you shim you are already compressing the spring alittle and now the spring is actually 'at work' all of the time so it will weaken that much faster or fail that much quicker.The best way is to replace them with what you need for the app. and not try to bandaid it.Think of it this way you have 2 15lbs weights in your hand at your sidehow long can you hold them at that position?Now raise them maybe 2 inches NOW how long can you hold them there?Stan
Old Jan 10, 2006 | 04:08 PM
  #108
I meant it would work for him, I wouldn't shim springs in my engine save for only enough that may be necessary if at all. I want as much coil bind clearance as possible.
Old Jan 10, 2006 | 04:12 PM
  #109
lurker's Avatar
Originally Posted by 69Roadster
Good find. I can buy that, lbs/inch^2 * inch^2 = lbs.
So my intake valves are 1.84". That gives me an area of 2.66 inch^2 (3.14*radius^2). Say I'm running 20psi... that means the force on my springs is 53 lbs.
Guess the question now is how much extra force do you need to keep a valve shut when there is 53lbs of force on it? Is 54#s enough? 70? 120???
Could be argued that if you had 74#s stock to keep it shut and you added 50#s trying to open it, that you'd then need to add 50#s to the 74 to get you back to stock performance right? Probably not as straight forward as that though .
EDIT: On second thought... Using a stock valve size and stockish boost of 8psi... force would be 19#s or 74 - 19 = 55#s keeping the valve closed. Sooo to get stock like performance with larger valves and 20psi I'd need 55 + 53 = 108# springs? Sound reasonable??
Luckily for the spring, it has to have enough force to follow the cam profile as it just starts to close (high acceleration point) and also enough to stay closed against boost pressure (when it's closed or very close to closed), BUT not both at once.
Going to a spring that can follow aggressive cam profiles should also allow you to run higher boost pressures.
BTW, you'll have to use the backside exposed area of the valve (seat inner diameter minus the valve stem) not the face diameter. The backside is the area that sees the pressure.
Old Jan 10, 2006 | 04:51 PM
  #110
Bad as L's Avatar
Hmmm... sounds reasonable.
What are the downsides to solid lifters? Would you have to adjust them frequently?
Finding a good one that works and then of course the adjustment of said adjusters. I tried the Second Street Speed rockers at almost 1800.00 per set and the first ones failed under my spring pressure (I was running a Comp LS1 spring at the time with 130+ on the seat) and they replaced them with a second design that looked really good until you ran them. I put about 50 miles on my set before a cylinder head turned into a sprinkler system (un-related to the rockers) and then Calightnin ran his set on the dyno and broke 4 lifters which spit the rockers off and bent 4 Ti valves and tried to trash his cylinder heads.
I never did anything else with my rockers after that....I can tell now they are made wrong and if you ran them with anything other than a stock spring the adjusters would break. So mine are on the shelf...maybe one day I'll call SSS and ask them if they need a good paper weight.
I decided to try a 4V with as many stock parts as I can run...except cams, valves and springs.
Dale
PS.....to answer your second question..YES...I think initially there would be a seating in period that would require several adjustments. When I took mine apart after only a few miles some had opened up and some had closed up a bit so you would have to chase them for an undetermined amount of time.
PSS....oh and one more thing....even at 22/23 lbs of boost it felt like it would rev to the moon...I could see shift points over 6000 rpm with the right cams, which I think would be a big boost in power.
Old Jan 10, 2006 | 05:21 PM
  #111
Bad as L's Avatar
Here is some more reading material: http://forums.modulardepot.com/showt...threadid=75182
And: http://www.mustang50magazine.com/tec...es/index1.html
I don't know why I posted the Yates article other than I thought it was funny that the only part in his engine that is a deep dark secret is the valve springs.
You can go to Hardcore50 or Turbomustangs or Modularfords and do a search and probably find 10 good valve spring posts....my point is this is not something new. Why is the Lightning community stuck in the dark ages ??? Sorry don't know that either....but if you look around there are other places you can get an education...not just here.
Dale
PS....the moddepot thread is a fun one....you have to wade thru the idiots and the cheerleaders but at the end it will be worth it.
Old Jan 10, 2006 | 06:41 PM
  #112
Tim Skelton's Avatar
Originally Posted by Bad as L
....the moddepot thread is a fun one....you have to wade thru the idiots and the cheerleaders . . .
And that is different from here how?
Old Jan 10, 2006 | 06:56 PM
  #113
Bad as L's Avatar
Too-shay
Old Jan 10, 2006 | 10:19 PM
  #114
Calightnin's Avatar
Had another thought in addition to my basic math...
What about pressure in the cylinder??? Doesn't it want to force the valve shut? I mean if there wasn't positive pressure then exhaust would be sucked in instead of pushed out right? Wouldn't that mean a 54# spring, with the cylinder pressure behind it, would keep the valve closed even with 53# of boost force trying to open it???
Man... it's complicated... glad I'm an electical engineer, electrons are easy .
Ding! You are correct. Maybe there is a mechanical engineer in you.
Old Jan 10, 2006 | 10:28 PM
  #115
Calightnin's Avatar
As Dale said: My experience with solid lifters was bad. Went through three sets (revisions) along with one set of aluminum rockers. The last set ruined a very expensive set of heads. I now have hydraulics. I wanted to use them to rev the engine (+6000 rpm), not because of high boost. By the way the hydraulic lifters I now run are out of a SVT Focus. See if anyone knows why.
Old Jan 10, 2006 | 11:13 PM
  #116
Isn't this really a "sorta" situation? At BDC after da bang, the piston has traveled down, the exhaust valve is opening, and the pressure subsides. Then the piston starts the exhaust stroke, but the exhaust valve is still open. So how much pressure is in the cylinder on the exhaust upstroke?
Or something.
I guess the question is how much pressure is there really on the face of the intake valve and when?
Old Jan 11, 2006 | 07:48 AM
  #117
SILVER2000SVT's Avatar
You guys are missing that you need a certain amount of closed pressure on the valve, including the exhaust valve to prevent chatter, and the valve bouncing on the seat. Jim mentioned that early on in this thread. Look at the closed force on a 5.4 NA motor with the same cams to determine what the starting point would be.
For a supercharged vehicle, On the exhaust side this might not need to change much until you run a more agressive cam, but the intake would need to have a higher seat pressure to over come the boost condition, bigger valves, etc.
Old Jan 11, 2006 | 11:03 AM
  #118
I now have hydraulics. I wanted to use them to rev the engine (+6000 rpm), not because of high boost. By the way the hydraulic lifters I now run are out of a SVT Focus. See if anyone can knows why.
Just a guess, they are designed to run higher rpms than the regular 2v jobbies, will fit the bores-4v lifters are smaller I think. I don't really know, care to school us in?
Old Jan 11, 2006 | 12:37 PM
  #119
99SVT's Avatar
Originally Posted by adrenalinowner
what i love about reading you post jim is how deep you dig the hole. first you try and tell everyone that you need to run big *** valve springs to make more power because of valve float. valve float doesnt happen in ohc vehicles, valve bind does and just becuase your parter in crime thats trying to sell blowers agrees with you doesnt mean its true. you need to stop snowballing everyone into thinking that valvesprings are going to gain them hp in stock or even mildly boosted trucks.
then you move on to and state bs about prostock apps and how they change springs every three runs, they dont they check valve lash every run and adjust it, if they need to replace a spring, guess what bud they change the freakin motor out.
next you move onto ultrasonic cleaners and you say there are only a few of them in the county. tell you what everyone call this number and ask for chris k, he will tell you that he has sold 13 of them last month alone and that he has sold 50+ last year.. 443-790-3853. they have been out for years dumbass.
most of you are morons for believing everything that comes out of nj. try checking out information for yourself or god forbid you pick up a book and read about something that your going to spend your hard earned money on. of course the dyno numbers will show an increase if you buy the new springs and have them installed by jdm because you will be on their dyno and they can manipulate that anyway they see fit and make you happy but whene you take it to the track and dont see an improvement who you gonna cry to? You wont becuaese you will be ot imbarrrassed.
warren johnson would kick you *** for mentioning him jim.
Ad
Old Jan 15, 2006 | 10:52 PM
  #120
Any new news? Why did all the SV guys bow out? More please.
