Cams
Old Nov 18, 2005 | 01:07 AM
JeffsLightning's Avatar
Cams
Are the left and right side cams exactly the same?
Old Nov 18, 2005 | 01:52 AM
Bad as L's Avatar
No....if you try to swap the two you will notice it right away...nothing lines up.
Dale
Old Nov 18, 2005 | 07:44 AM
danoid5631's Avatar
Dale
Yup you will be able to tell.
Old Nov 18, 2005 | 08:58 AM
Casey02L's Avatar
If I remember right there was a number stamped in them and there was a "R" and a "L" to it. I went off what the boxs said.
Old Nov 18, 2005 | 11:22 AM
Ok...thanks
Old Nov 18, 2005 | 11:23 AM
LightningTuner's Avatar
Well, you could put them in backwards, but then you'd have one timing gear on the back of the motor .
