The findings of my OP POS motor
Old Nov 17, 2005 | 09:46 AM
415cid Goose's Avatar
Angry The findings of my OP POS motor
Here is a list of missing parts and stuff done wrong. The list keeps getting bigger. This is what I have so far. Will update the more I know
The oil slinger that goes on the crank behind the rear main seal(missing)
Rear main was a mess
The crank has several deep grooves in it
Oil was a light browish green color
Kind of like the milkshake color when coolant mixes with oil
The springs look stock, but not 100% sure on that
Used block ( paid for a new one)
Lower end has main bolts, not studs
Header gaskets were all leaking
Wrong header gasket used(was not a Ford gasket)
Header bolts stripped in heads
Nuts and bolts in wrong places
Here is more stuff found today:
The timing cover is broken
Midplate between the motor and trans was mangled, and the converter studs were hitting it
Heads were supposed to have mild porting. Intake & Exhaust were untouched.
Here is a good one: All the spark plugs were seized in the heads
Old Nov 17, 2005 | 10:00 AM
Hostile03SVT's Avatar
Dam... thats why 2 things will happen when i do my engine.
1. Sal will build it.
or
2. I will build it.
you would think you spend all that money for a new high performance engine that you would trust it would be done right. there goes another customers trust out the fricken window.. some vendors shouldnt be called vendors at all, they should be call thieves... i know you will be taken care of with our tuner.. i seen your truck the last few times i was at the shop. i dont want to mention our tuners name because at the time our tuner wanted it to be hush hush, unless something changed since i last talked to him.. good luck to you pal, hope your on the road soon..
Old Nov 17, 2005 | 10:03 AM
SVT F15O's Avatar
Welcome to my world! HaHa!
Old Nov 17, 2005 | 10:07 AM
St Louis Lightning's Avatar
OP =
Old Parts?
Omitted Pieces?
Outrageous (business) Practices?
Tommy is such a hack. Sorry Andy..
-Mark
Old Nov 17, 2005 | 10:19 AM
Thanks a lot Mat
Old Nov 17, 2005 | 10:23 AM
or
2. I will build it.
I know I'm in good hands now. Can't wait to get the truck back. I will not mention anyone's name yet.
Thanls for all the support guy's.
Old Nov 17, 2005 | 12:46 PM
Originally Posted by St Louis Lightning
OP =
Old Parts?
Omitted Pieces?
-Mark
Thanks Mark. All will be well soon.
Old Nov 17, 2005 | 01:42 PM
Stl01SVT's Avatar
Andy, with the many problems you had with that engine from the start. I thought that a few things were done wrong. But, not a hack job like that.
Hopefully, this thread will put an end to Tommy's engine building career.
-Mike
Old Nov 17, 2005 | 02:25 PM
tommylightning's Avatar
The oil slinger and rear main seal, I had paid good money to have replaced (over $600) If you have aproblem with that you need to contact the company you brought it to.
The crank grooves I can't explain but the place where you took it to to repair the rear main seal should have put a sleve on it.
Don't want to get in to that but sounds like you have a head gasket problem.
Springs are CompCams behives
This was discused when getting a new block was hard to do.
?? This one I am confused on. I always build with head and main studs. The side bolts are new OEM streth to yeld.
Not sure about the three mentioned above. I know you had said that the shop had to take extra time to remove and replace the header(s) when doing the rear main seal.
This is also one that I do not understand as I know where all the nuts and bolts go (I could look at them in a pile and tell you where they go).
Again I will go back to the people that did the rear main seal repair. They removed the trans and put it back, I was not the last person to take it apart.
Heads had a 3 angle valve job and larger valves installed.
I did not post this to start a war but to post my side of the story. If we can keep this civl I will entertain any questions on any findings.
Old Nov 17, 2005 | 02:45 PM
whip's Avatar
What did you find on Mats motor?
Old Nov 17, 2005 | 02:47 PM
JeffsLightning's Avatar
Sounds civil and legit... Can Tommy share the information?
Old Nov 17, 2005 | 03:00 PM
I would comment if I had any info but I do not.
Old Nov 17, 2005 | 03:04 PM
whip's Avatar
Is that the same info you had going into the build? None?
Old Nov 17, 2005 | 03:50 PM
SVT F15O's Avatar
Don't even get me started buddy, you have all the info you ever needed. PLUS all of MY money!
What do I have>??? A $8,000 paper weight.
You still have the chance to do the right thing just so you know. -Mat-
Old Nov 17, 2005 | 07:12 PM
IN "PSP" I TRUST!!! I WAS WARNED EARLY ENOUGH IN ADVANCE TO STAY AWAY FROM "OP".........
