The findings of my OP POS motor
Originally Posted by Shorty
OK new guy. Who said you could use common sense in our forum.
Originally Posted by adrenalinowner
How much research did you guys do before buying a motor from an unknown?
Just did a search on google on outrageous perfomance motors and guess what? nothing came up.
["outrageous performance" engine lightning] turns up 535 hits.
Originally Posted by tommylightning
. . . Heads were supposed to have mild porting. Intake & Exhaust were untouched.
Heads had a 3 angle valve job and larger valves installed. . .
If you are here to save your reputation (a completely futile effort), try starting with an intelligent response. If you can't compose an intelligent post, why should I trust your ability to build an engine?
Originally Posted by Krix330cic(NJ)
ok. built engine, stage III cams, KB, 14lbs boost, 300 shot??? built engine kb a good tune on a race tune would and should get you into the 10s.. thats crazy.. but then again it is almost 6000lbs.. its still only one customer of OP that is satisfied.. only 1................................................. .........
Here is a list of missing parts and stuff done wrong. The list keeps getting bigger. This is what I have so far. Will update the more I know
The oil slinger that goes on the crank behind the rear main seal(missing)
Rear main was a mess
The crank has several deep grooves in it
Oil was a light browish green color
Kind of like the milkshake color when coolant mixes with oil
The springs look stock, but not 100% sure on that
Used block ( paid for a new one)
Lower end has main bolts, not studs
Header gaskets were all leaking
Wrong header gasket used(was not a Ford gasket)
Header bolts stripped in heads
Nuts and bolts in wrong places
Here is more stuff found today:
The timing cover is broken
Midplate between the motor and trans was mangled, and the converter studs were hitting it
And the latest
Here is a good one: All the spark plugs were seized in the heads
And the latest
The oil slinger that goes on the crank behind the rear main seal(missing) Show picture of that please
Rear main was a mess what do you mean? was it leaking?
The crank has several deep grooves in it again, pics would be nice
Kind of like the milkshake color when coolant mixes with oil Did it lift a head? how much boost were you running?
The springs look stock, but not 100% sure on that Any news on that?
Used block ( paid for a new one) Typical
Lower end has main bolts, not studs Not good if you paid for studs
Wrong header gasket used(was not a Ford gasket) So because they arent Ford gaskets, they are wrong? Most header companies supply their own gasket FYI
Header bolts stripped in heads stripped in installation or during removal?
The timing cover is broken again, pics would be nice
Midplate between the motor and trans was mangled, and the converter studs were hitting it What midplate? the flexplate that the converter bolts to or the shimplate that goes over the block dowells? how could the converter studs hit that? Pics?
And the latest
And the latest
Adrenalinowner
