Waste of time going to the track?
Old Aug 21, 2005 | 02:12 PM
Blown347Hatch's Avatar
Originally Posted by Rob_02Lightning
Your right
What the hell, I hadn't made any NON N20 passes since 2002, I was due anyway, CEPT is should have been kissing the 11 sec mark off spray, give me 40 degrees colder and I'll do it
Rob, what DID you run in the heat (MPH & ET)?
You have stock heads (no porting) and stock valve sizes? No cams? I know you're running an Eaton again, what mods are you currently on?
Old Aug 21, 2005 | 03:21 PM
SVT_KY's Avatar
Only reason to go to the track between now and November is to
be with good freinds and have a bunch of fun ... The records come later
in the cool weather ... I ran mine in late October ...
Old Aug 21, 2005 | 08:48 PM
wydopnthrtl's Avatar
I did nearly identical ETs and speeds last week. It was 89F & I was at full weight including hitch and spare. Ran all 13.1s @ 104-106mph. (nitto 404s)
Rich
Old Aug 22, 2005 | 05:44 AM
TXSVTLIGHTNING's Avatar
55° hotter (102°) at the track made me slow down over a 1/2 second.
12.68 @ 108mph in 47° (had 100oct +track prog. too)
13.35 @ 102mph in 102° (had 93oct +street prog. too)
Old Aug 22, 2005 | 09:07 AM
That's good info TXSVTLIGHTNING. I guess I won't drive mine into the lake just yet.
Man, these trucks turn into junk in the heat. It's gotta be because of the S/C and that the Eaton's make alot of heat to begin with.
