Comp behive spring pressure?
Old Jul 14, 2005 | 05:39 PM
chimshady1's Avatar
Question Comp behive spring pressure?
Just curious if anyone knows the spring pressure for the comp behive spring for our trucks. Having my heads put back together and just want to see if the springs are still at there proper rate.
Old Jul 14, 2005 | 06:33 PM
chimshady1's Avatar
http://www.mustangtuning.com/cocasps.html
Found it, but figured id post it for anybodys eles needs
Old Jul 14, 2005 | 08:40 PM
Magnum Powers's Avatar
They are 80# at the seat (1.64" installation height) Thats the height your builder should use to test them.
Give me a call, I'll tell you how to upgrade your seat pressure for better performance.
503 357 5444
Charles
Old Jul 14, 2005 | 10:31 PM
chimshady1's Avatar
503 357 5444
Charles
Then the ones i listed are wrong? I'll give you a call tommorow. Thanx Charles
Old Jul 14, 2005 | 10:49 PM
Blown5Pnt4's Avatar
Jay, you finally gettin that damn thing back together ??? Its about time...lol J/k throw me a call on my cell man...
Old Jul 14, 2005 | 11:30 PM
Jay, the 95 pounds they call out on the link you provided is at 1.57" installed height. The standard install height if you just install the springs is 1.64"; the seat pressure at that install height is 80 pounds. An installation height of 1.57" requires a .070" shim that Comp Cams does not tell you about when ordering their Stage II cams. I'll tell you how to do better then that when you call tomorrow, with your cam I think we should be able to get 100 pounds at the seat.
Charles
