Wash, Clay Bar, and NXT Gen Wax, WOO HOO....
I also had trouble with the NXT wax...
Took me a very LONG time and a very SORE arm to get that stuff off the truck..
Looked good when I finally got it off...
wasnt sunny.. wasnt hot.. bout 75ish... I'm also hesitant to use it again.
I think I'll try the Zaino next time...
Looks grrrrrrrrrrrreat everyone,
I agree 100%
The 1st time I used it I was afraid to listen, do the entire truck and then let it dry before removing, (usually I do an area at a time w/ other wax) And I actually did do it in direct sunlight on a hot day, still no problem, the stuff wipes off like it's not even there, woo hoo................
Are we all using the same stuff ??? there are diff types of NXT Gen Wax.
I use the spray on, are some using the new Paste ???
I do find with Meguiars products, some work better than others. For instance I live on the Quik Detailer Spray, I can do a quick touch up on the L in no time, yet the Reg Meguiars Spray wax (in the red bottle) I found absolutely impossible to remove
I use this one
Last time I did it, it came out just as good too
Originally Posted by WaveBlaster785
If NXT won't come off easily then you are doing something very wrong. Are you applying it in 100 degree heat and direct sun?
Nxt is the easiest wax I have ever used.
I use this one
i bought both the spray wax and the liquid wax. are you guys saying you only use the spray wax. i figured i would have to put a good coat of the liquid wax on and just do the in between coats with the spray.
Victor
Victor
Originally Posted by Odellintulsa
Took your advice Rob heres my before and after
and one for shock therapy haha
Originally Posted by Suavy
What is NXT? I guess I missed the boat!
Where can you get it?
Peace,
Suavy
Peace,
Suavy
Rob's post was talking about the "Tech Wax"...It's very easy to remove (In most cases)
Here's the link to the whole "NXT" line from Meguiars:
http://www.meguiars.com/whatsnew/nxt05.cfm
Most auto parts stores carry it, AdvanceAuto, Autozone, etc...I think I even saw it at a super WalMart.
Originally Posted by emig5m
How exactly did you get those swirl/spider marks out in the first pic? (the ones to the right of the Lightning badge). Did you use a swirl remover or something before the NTX or was it just the angle/glare in the first pic? I wish I could get my paint to look that "smooth" in your second and third pic!
I used dawn to strip the zaino that was on the truck. then I used mothers clay bar on the spots that had swirls or hairline scratches. Then the NXT paste let dry for 30 min and it comes off with one wipe.
I used NXT liquid wax on my Silver, and it shined it up big time! I didn't have any trouble getting it off, i put it on one section at a time and it would dry as i went. I'm going to put another coat on, and then i'm going to use the spray wax when i hand wash it. I figure after that i'll need
to look at it in the sun!
