Where to put sensor for engine temp.
Old Jun 20, 2005 | 08:49 PM
Whitelighting's Avatar
Question Where to put sensor for engine temp.
Hello all heres what i did made a tee put the jdm efan sensor in 1 side of the tee put the gauge sensor in the other side of the tee.Tee is located in the back btm end of the block....Heres the problem fan is not cutting on sensor is not getting the right reading ,how do i know this took the tee out put the sensor to the fan back in the block drive it around sure enough the fan comes on put the tee set up back in never comes on even if its 97 degrees out side so where can i put the sensor for the gauge.The hottest the gauge has read is 180 degrees ...its not reading right either in the tee at 150 degrees on the gauge i check the fluid in the coolant tank sure enough the fluild is getting pumped so that means its over 180 degrees to open the termostat.So where do i need to put the sensor for the gauge?
Thanks for any help.Bob
Old Jun 20, 2005 | 08:52 PM
Stl01SVT's Avatar
I drilled and tapped my thermostat housing to install the coolant temp sensor.
Old Jun 20, 2005 | 09:09 PM
LightninMike's Avatar
there is a plug on the opposite side of the block in the same location maybe that would work for ya
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
like so...
The only drawback (if you consider it one) is the gauge won't read until the thermostat opens. Good way to see if the stat fails IMHO.
Bob
Old Jun 20, 2005 | 09:10 PM
Hmm never thought of that...
Old Jun 21, 2005 | 08:58 AM
superfords's Avatar
me too...
Old Jun 21, 2005 | 09:09 AM
Stl01SVT's Avatar
My gauge registers temperature as soon as the truck starts to warm up, don't have to wait for the thermostat to open.
Old Jun 21, 2005 | 11:18 AM
Learo2000GT's Avatar
Do you recall the size of the tap you used to make this work?????
Old Jun 22, 2005 | 04:18 AM
Thanks for the info.
Bob
