Lightning drop spindles now available
Old Jun 10, 2005 | 08:48 PM
MHMCGILL's Avatar
Originally Posted by halflife
Hey Tim or other suspension guru's
I want a drop with stock ride quality. I have 22's so I will not be hitting the road coarse anytime soon. If I get the drop spindles for the front, what should I do to drop down the rear? I have a 2003 with 2 or 3 inch drop shackles right now.
Thanks for the info
That's what I was wondering too. Would a c-notch be the only option for the rear? If it is, then I guess that the Roush route would suit me better.
Old Jun 10, 2005 | 09:39 PM
Tim Skelton's Avatar
Originally Posted by thepawn
. . . I was waiting for the XMS motorsport bumpsteer kit, but it seems to have never come to fruition. . . .
Lightning vaporware. Strains the imagination.
Old Jun 10, 2005 | 09:42 PM
The c-notch has nothing to do with how you lower the rear, only how much you lower it.
I'm at a 3-4" drop. I had to grind down the lip on the frame rail and use really thin bump stops to keep from bottoming. Keep the drop less than 4" (on an 02 anyway, more room to drop on 03/04) and you should be fine.
Old Jun 10, 2005 | 10:26 PM
MHMCGILL's Avatar
Thanks Tim I had no idea that a c-notch was for how much I droped the rear, not how to drop.
Tim don't make me your special project please. Maybe I should have written something like, If I use spindles for the front will I need to do a C-notch to get the correct stance. Is that better Tim?
Old Jun 10, 2005 | 11:53 PM
My Red-Rocket's Avatar
Tim, what are you using to drop the rear end to get 4" without using hangers? Are there any issues with the panhard bar then? Sorry for the
hijack. Thanks.
Old Jun 11, 2005 | 03:54 AM
Xx 01 SVT xX's Avatar
hijack. Thanks.
JLP sells 4" shackles for $109
Old Jun 11, 2005 | 11:46 AM
TrackBeast's Avatar
hijack. Thanks.
The panhard bar will work with a 4" drop. Not sure if you go lower.
This has been discussed exhaustively before. Anything more than a 2" shackle and you will have a really loose rear end. I call that the sail boat effect. To do it properly, you need to replace the front hangers to adjust the desired drop.
TB
Old Jun 11, 2005 | 12:36 PM
. . . Maybe I should have written something like, If I use spindles for the front will I need to do a C-notch to get the correct stance. . . .
Yes, that would have been much better. I cannot read your mind, only your words.
My reply was a genuine response to your post. If I were just taking a shot at you, I would not have bothered to write the second paragraph.
Old Jun 11, 2005 | 12:42 PM
Tim, what are you using to drop the rear end to get 4" without using hangers? Are there any issues with the panhard bar then? . . .
2" shackles and Hotchkis leafs.
When you go that low, the bed crossbrace just above the diff mount must be clearanced with a ball peen hammer or a saw to allow full vertical travel of the axle. Other than that, it's fine.
Old Jul 9, 2005 | 06:19 PM
Eds 01 Lightnin's Avatar
Originally Posted by TrackBeast
Many Lightning owners have been waiting for this part which should address the most annoying problem resulting from drop springs; BUMP STEER.
The Belltech part # is 2350 and availability is 2-3 weeks. I just called Summit and the cost is $229.99. With millions of F-150s out there and 1 supplier, the best thing to do is to place a back order.
TB
Is there any updated info on these lowering spindles? This is the route I want to take in order to maintain the stock ride quality!
What Is the "Summit" referred to- Summit Racing? Anyone have a link?
Old Jul 10, 2005 | 09:05 AM
supragod98's Avatar
Sorry for the dumb @$$ question but what is bump stear?
Old Jul 10, 2005 | 11:30 AM
It's the tendency of a vehicle to change directions (i.e., steer) when the vehicle goes over a bump. It is caused by misalignment of the steering and suspension arm pickup points.
results of title-only search for "bump steer"
results of Google search for "bump steer"
Old Jul 10, 2005 | 11:32 AM
Originally Posted by Eds 01 Lightnin
. . . What Is the "Summit" referred to- Summit Racing? Anyone have a link?
www.summitracing.com
Old Jul 10, 2005 | 11:44 AM
Silver_2000's Avatar
Any of you running Roush springs / shocks and experiencing bump steer ?
Old Jul 10, 2005 | 12:18 PM
Good info! Thanks for the link, Tim!
