big pulley problem
Old May 3, 2005 | 02:30 PM
onlyfordman's Avatar
LatemodelRacer2
I have over $200 in the kit because I didn't get it all at the same time, but it is all new. I will sell it to you for $170 plus ship if you want it. Let me know.
Old May 3, 2005 | 02:33 PM
easterisland's Avatar
I'd be worried about what you are going to do if your accessory belt breaks...
Old May 3, 2005 | 02:45 PM
LatemodelRacer2's Avatar
very true
Old May 3, 2005 | 04:04 PM
SVT_KY's Avatar
Originally posted by onlyfordman
Ya, I have tried everything and my local Ford delear
can't get it off and yes I am loosening to the right. If anyone
whats to buy a 4lb pulley quick change system then let me know.
I know someone that can get it off ...
< Evil Grin as he starts up the Sawzall! >
Old May 3, 2005 | 04:09 PM
fast1's Avatar
Originally posted by WaveBlaster785
You know it has counter clockwise threads right?
Exactly what I was thinking...
Old May 3, 2005 | 04:34 PM
RustySocket's Avatar
Those pulleys are tight but not that tight. I put the front of the truck up on stands. Bolted the converter to the bell housing and put a 1/2" breaker bar on the crank at the 6o'clock position and put my back up against the driver side tire and used my foot to break it loose.
Your not gonna break the crankshaft.
Whatever you do I'd figure out how to get it off before you accesory belt breaks and leaves you stuck.
Scott
Old May 3, 2005 | 05:37 PM
Believe me I wish I could get it off but you don't understand. I have put over 300lb tq on it and it didn't budge. They broke a wrench at the ford place trying to get it off. I have spent over 15 hours my self on it. My dad owns a big rig shop and nothing in there, that will fit in the engine compartment, that will take it off. I pulled my radiator so I could get my 3/4" impact on it and it broke my impact grade wobble head socket. It wouldn't go on directly because of the cross frame thats why I had a wobble head socket on it. So anyway if anyone wants to buy my system I will sell it. I am going to order the 2.60" upper pulley.
Old May 3, 2005 | 05:52 PM
brain bypass's Avatar
maybe try some sort of penetrating spray?
Old May 3, 2005 | 05:59 PM
dirtchicken's Avatar
Have you tried heating it with a torch yet????
Old May 3, 2005 | 06:06 PM
Slick_Sammy's Avatar
that's how i've gotten nuts off tractors & bush-hogs. that and a 4-5' pipe on a 1" breaker bar!!
Old May 3, 2005 | 06:26 PM
they tried heating it at the ford place and couldn't get it off.
Old May 3, 2005 | 06:39 PM
Something ain't right.....
Old May 3, 2005 | 09:14 PM
Silver_2000's Avatar
I have seen 2 methods work in this case
One is a sawzall and the other is putting about 200+ ft lbs of torque on it and shocking it to break it loose ...
So put your legs into it till the breaker bar is about to bend in half then have someone rap on it with a 3 lb hammer....
Of course the older trucks had a flange that could be unbolted and just replaced.
Doug
