reverse not working
Old Apr 4, 2005 | 08:38 PM
Kobrakai's Avatar
reverse not working
ok so now another problem with my L, the reverse wont work until i drive it for a few miles and then the o/d light will start to flash and after that i can use reverse, this truck keeps giving me problems, if its anything serious i think im going to sell it and get a TT Quattro 3.2, I'm just getting sick of always having my truck in the shop....any ideas on what it could be?
Old Apr 4, 2005 | 09:37 PM
dealerjim's Avatar
Do you have headers?
Old Apr 4, 2005 | 09:55 PM
Kobrakai's Avatar
yes i do
Old Apr 4, 2005 | 09:59 PM
cpeapea's Avatar
could possibly an o/2 wire melted on the header. you should check all the fuses. sometimes this will ground out after melting and cause it to blow a tranny fuse
Old Apr 4, 2005 | 10:03 PM
dealerjim's Avatar
Mine had similar symptoms and it ended up being one of the O2 sensor cables melting and grounding out against the passenger side header.
Old Apr 4, 2005 | 10:06 PM
Kobrakai's Avatar
ie had it in the shop once before for that...looks like ford is going to be doing some work for free :-D
Old Apr 4, 2005 | 11:48 PM
Whitetrash SVT's Avatar
-W/ a blown fuse you will still have good reverse. It is a hydraulic engagement.
-Step 1 is always check fluid. Check for proper level, discoloration, burnt odor.
Since the problem seems to occur when cold(based on your complaint), try putting it in D1 while cold. If there is no engine braking it would indicate a fault in the low/reverse clutch or a problem w/ the low/reverse piston or seals.
BTW, how is your 2-3 shift?
Old Apr 5, 2005 | 12:29 PM
Kobrakai's Avatar
d1 works fine from a cold start... 2-3 shift is kinda high, maybe 2900 rpms or so just cruising
Old Apr 5, 2005 | 01:19 PM
I appologize man.It was late and my post was somewhat vague. I should have said let your foot off the gas in D1 at around 10-15mph or so and see if it feels like the truck noses downward as if the e-brake were on or something.
Old Apr 5, 2005 | 02:44 PM
Kobrakai's Avatar
letting off the gas at a 20 mph roll makes you kind of lean forward, and i noticed the reverse starts working as soon as tghe o/d light starts flashing, never before that....
