Leaking Cooling System???
Old Mar 27, 2005 | 05:21 PM
LightningJMP's Avatar
Question Leaking Cooling System???
Recently I have been noticing my coolant level has been dropping. The tank is empty at least once a week, I drive 75 miles a day at most. There were spray patterns around the reservoir cap so I changed that but no help. So I replaced the tank, thermostat, all the hoses in that area, and flushed the system but still no change. I still get spray pattern and still lose coolant at the same rate. Does anybody have any ideas as to what might be causing this, it seems there must be a block in the system somewhere. The truck has approx. 85000 miles and does no run hot or show any signs of a bad cooling system. Any help is appreciated, I want to get this fixed.
Old Mar 27, 2005 | 05:35 PM
dealerjim's Avatar
Sounds like you could have a bad head gasket allowing cylinder pressure to enter the cooling journals. Is there any grayish residue in your overflow tank?
Old Mar 27, 2005 | 05:38 PM
I have not noticed a grayish residue but the coolant looks like a rusty color.
Old Mar 27, 2005 | 05:44 PM
dealerjim's Avatar
Hmmm. Have you checked it right after a WOT run? Thats usually when it'll spray out of the reservoir if it's a head gasket.
Old Mar 27, 2005 | 05:46 PM
I will check that later today, thanks for the info.
Old Mar 27, 2005 | 05:53 PM
l-menace's Avatar
WHICH coolant Tank?
I notice you have a '99 Lightning, is it the Intercooler Tank, If so, I'm sorry to break this to you. $$$$$$
Read here:
https://www.f150online.com/forums/sh...hreadid=174350
Old Mar 27, 2005 | 06:09 PM
It is the engine coolant not the intercooler tank.
Old Mar 27, 2005 | 10:35 PM
cpeapea's Avatar
im thinking head gasket.
