Help Oil Pressure Issue
Old Mar 24, 2005 | 07:42 PM
  #46
l-menace's Avatar
Suavy,
Have a safe trip, and forget about the truck and spend some quality time with your family.
Shoot me an E-mail when you get back, I have next week off.
Old Mar 24, 2005 | 08:29 PM
  #47
Suavy's Avatar
Originally posted by l-menace
Suavy,
I'll be here in my garage pulling my motor Mark?
My daughter is due on the 9th so it's any day but I plan at least on pulling the motor before I go.
PS. I found that other mid pipe for you so when ever you want it.
Suavy
Old Mar 24, 2005 | 09:32 PM
  #48
l-menace's Avatar
Suavy
Alright, I thought you were waiting until you returned.
I'll shoot you an E-mail.
Old Mar 24, 2005 | 09:37 PM
  #49
Suavy's Avatar
I thought so too but I have 4 days to work with so I'm gonna try to get her done!
Old Mar 24, 2005 | 09:43 PM
  #50
Bad as L's Avatar
Sauvy
The reason I went back to the stock pickup with the big pump is because I didn't like the way the Cobra pickup fit. The pickup sits too far forward and too high up from the bottom of the pan and isn't good for drag racing IMHO.
Also...not sure if the Cobra pump would have that kind of an effect on your engine....causing an oil spray....the pump gears are only about 1mm wider than a 2V pump and was made that way to feed extra oil to the 4V heads, its not that much bigger than stock. Again my .02
Dale
Old Mar 24, 2005 | 10:38 PM
  #51
Suavy's Avatar
Originally posted by Bad as L
Sauvy
Dale
Thank you Dale, as always I trust and value your input!
Have a safe and blessed Easter I'll write back on Tuesday with the details.
God Bless Everyone this Easter,
Suavy
Old Mar 29, 2005 | 08:48 PM
  #52
Suavy's Avatar
Up date got the engine 1/2 way out just need to disconect the exhaust, unbolt the pwr steering pump, air compressor, and then seperate the tranny.
Engine machine shop on stand by to get it tore down. We did rule out the oil coller assy. There is a tab on the bottom of the abapter for oil filter cooler; that won't let it locate with out proper pos. Even so it has a distribution rin that allows oil to flow arond that area.
I was concerned cuz I used a coller from a 2001 truck instead of my old 2000.
Thank you every one for your input!
Peace,
Suavy
Old Mar 29, 2005 | 08:58 PM
  #53
BigBobsL's Avatar
If you are using a stock pick upon a hi vol pump, my gues is you are sucking air into pump and that could be your problem.
Old Mar 29, 2005 | 09:03 PM
  #54
Suavy's Avatar
Bob, I used a stock pump ever since I started racing my L. However, last year I went with a HO pump but it used to send oil droplets all over my engine at WOT. This year we went back to the stock type pump. I changed it out again last week still had the same problem. I made dbl. sure the O-ring was on right!
Stock pump with stock pick up tube and O-ring.
Thanks for your input.
Peace,
Suavy
Old Apr 4, 2005 | 02:12 PM
  #55
Suavy's Avatar
Up date,
Got the motor out pulled the pan there was metal shavings on the pick up tube screen.
We were able to get it to turn with some force, to get the torque converter bolts off.
The motor gose back to the builder tomorrow morning to find out whats what.
Pray for me!
Suavy
Old Apr 4, 2005 | 02:48 PM
  #56
wydopnthrtl's Avatar
Ouch!
It'll turn out in the end. Sometimes the road is bumpy along the way..
Rich
Old Apr 4, 2005 | 04:18 PM
  #57
Suavy's Avatar
Like you said before Rich, at least it didn't happen on my way to TX.
We will find out tomorrow morning whats up?
Suavy
Old Apr 4, 2005 | 06:20 PM
  #58
superfords's Avatar
wow, sounds familiar...
sorry to hear about this Suavy, very dissappointing.
good luck.
let me know if I can help in any way.
later,
chris
Old Apr 4, 2005 | 06:40 PM
  #59
Suavy's Avatar
good luck.
later,
chris
Chris, I do need your help? How can I prove that they may have not installed a bearing right? Or let's clearance. I know that he had to order a special set of bearings for it?
The heads apear to have oil puddles up top but I want the cam caps removed to look for gaulding.
Any tips you could give or definet things to look for?
Suavy
Old Apr 4, 2005 | 07:28 PM
  #60
Suavy's Avatar
I want to publicly thank superfords for his time and his guidance. I kept the poor guy on the phone for 1/2 hr.
Thanks again Chris!
Peace,
Suavy
