? for the MP crowd
Old Mar 13, 2005 | 08:37 PM
tlfwatch's Avatar
Talking THIS IS ONE RACE I WANNA SEE
Originally posted by Fast Gator
Look at it this way.............
21 lbs of boost is 21lbs of boost, no matter how you cut it.
The difference is how fast/hard the motor reaches that total boost.
Think of an open door...........
Slaming the door wide open, or swinging the door wide open. See the difference it would make on the surrounding door frame?
I ran 21lbs on a stock long block for many miles. It was dyno tuned and I refrain from those 55mph kickdown. Now with the ported heads and same pulley combo, Iam running 18 lbs boost. But I know how to fix that problem
**EDIT**
Oh yeah, that Lightningrodder Low Budget Beast will be getting its *** handed to him (April 16 @ SSOTN Spring Nationals) by the F150online Lower Budget Beast Slayer if he shows up
I will be there to see this race
Old Mar 14, 2005 | 06:26 AM
8UR LS1's Avatar
mp/kb
Originally posted by l-menace
I'm a HUGE Magnum powers fan, however the KB is a better blower.
Remember it's not peak HP that counts it is the Space UNDER the curve! if the KB produces more power at lower RPM's then it will have more space under the curve.
With that being said. The Most bang for the buck award goes to MP.
The KB does produce more power at lower rpms, which i believe is more harmful to a S/B truck over time, especialy on those 50+ mph kickdowns ect,ect.
But for us with stock blocks that cant yet afford a built bottom or even the KB, the MP is a great option.
My stock fuel system is pegged with the MP making 463/530 street tune and daily driver 2.7 upper,4# lower, twin 100mm idlers, 67" Gates belt and no LT's.
I do need a MP bracket as well as a new belt tentioner since my boost has fell off lately (18 to 15) within about 3k miles or so due to belt slippage/glazing.
Im actually saving up for a 4 valve to see how hard I can really spin this MP with that high reving 4v.
Old Apr 5, 2005 | 04:40 AM
supragod98's Avatar
I am thinking of going this route:
Magnum Powers Blower case
Magnum Powers Idler brace
Dual 255 Fuel pumps
60# Injectors
SCT Big Air MAF/Diablo MAFia?
Would this be good for 500HP on my stock block?
Old Apr 5, 2005 | 11:04 AM
JimIII@jdm's Avatar
Former Sponsor
Dual 255 Fuel pumps
60# Injectors
Sounds like an awesome plan and similar to the route Im going. At that power level its all in the tune, I would highly suggest a dyno tune. With the pumps, injectors, and maf you are definatley building some protection for it. We have the injectors and SCT maf on sale untill the end of April right now.
JimIII@JDM
Old Apr 5, 2005 | 02:28 PM
iron horse's Avatar
The Magnum is good enough to push you into the 10's, at half the price of a KB. If thats your goal.
Thats a very interesting comment. I did't realize the MP was capable of making that kind of power.
Old Apr 5, 2005 | 02:32 PM
JimIII@jdm's Avatar
Former Sponsor
The Fridge ran 10.99 with about 580 to the tire. Gator just made that on his street tune.
JimIII
Old Apr 6, 2005 | 01:34 AM
supragod98's Avatar
Jim any chance you can work out some sort of package for me? Every little bit helps.
