Maybe I should put the 4lber back on?
Guess we will see how mine and Bob's truck last. I've been running the KB since fall of last year with a 8.5 and 8.75 lower; gonna step it up to the 9" lower all the time. Pretty cool to have 2 trucks testin out the factory long blocks here in the same town with the belief that it is actually all in the tune
Originally posted by Bob Tompkins
Im on the stock bottom end
Spyder the wideband I have mounted on the column is a FJO with greed led display. The control box is sticky taped to the undehood fusebox cover where you need to make two connections for it; key on 12v and ground.
The O2 sensor harness was extended to reach the rear of the left cat on my dynatech long tubes where the sensor is screwed in to a bung. Its a simple deal but I have not hooked up any of the data logging stuff yet.
Bob
Bob
Bob
Bob -
Yes I had to extend the wideband sensors wire alot because I wanted to mount the control unit for the wideband up in the engine compartment. If you look at this pic you will notice the control unit mounted on top of my underhood fuse box.
The dynatech cats already have a unused bung in the rear of there cats. I just simply removed the plug and installed the sensor there.
Here is a pic of the dynatech cats for reference.
Hope this helps.
Bob
Hope this helps.
Bob
Bob -
Hope this helps.
Bob
Bob -
Hope this helps.
Bob
Jeff im running a 6lb lower (9") lower and a 3" upper
I wont be posting again till Monday. I am heading out to Houston for the national Supra meet with a few freinds. The truck is gonna chill in the garage till I get back.
damn bro I should have read this closer. did you go to the supra meet that night out in north west houston. If so I was out there in my wifes silver X5 BMW. would have been nice to meet you. see you around. Blaine
Blaine -
Yes I was there with my 2 of my buddy's in a borrowed mini van (we were big pimping). I built a single turbo supra 2002 but sold it in late 03 due to getting married and buying a new house.
I am trying to work some things right now to get back into another Supra with a big single on it and keep my L. It would be pretty bad *** to tow my Supra to Texas 2k6 with my L.
Bob
Bob
Blown -
The pillar pod is a lotek version that is no longer made from what I understand. The fit is actually not that good. I do want to replace with it something but I have been lazy as of late.
georgia -
I have not any problems with my wideband being behind the cat. It works just fine. Alot of dyno's use a tail pipe probe but they can .1-.2 leaner then a farther up stream reading. The last time I had the truck tuned the dyno's sensor was installed in front of the cat and there was no difference in the readings.
Bob
georgia -
Bob
Bob
Bob
Blown -
Bob
Blown -
Bob
