Maybe I should put the 4lber back on?
Old Mar 9, 2005 | 06:28 PM
Bob Tompkins's Avatar
Peak hold on my boost gauge, after some street tuning
Old Mar 9, 2005 | 06:32 PM
RAMAIRSVT's Avatar
Re: Maybe I should put the 4lber back on?
Hell no pully up I'm rocking 24 rolling down the street! un less that's a stock bottom end!!!!
Old Mar 9, 2005 | 06:48 PM
Spyder207's Avatar
Bob,
Can you give me any details on the AF Gauge you have mounted there? Any installation details you can share would be great as well.
Thanks,
Old Mar 9, 2005 | 07:17 PM
Ruslow's Avatar
DAMMMM! 20 psi boost running down the road with an a/f of 20.00 and the door open no less.You got some might big ones...... j/k Stan
Old Mar 9, 2005 | 07:37 PM
NTIMD8's Avatar
Sweet Bob, I hope I see 20psi in my truck since we have the same pulley combo
Old Mar 9, 2005 | 07:41 PM
Im on the stock bottom end
Spyder the wideband I have mounted on the column is a FJO with greed led display. The control box is sticky taped to the undehood fusebox cover where you need to make two connections for it; key on 12v and ground.
The O2 sensor harness was extended to reach the rear of the left cat on my dynatech long tubes where the sensor is screwed in to a bung. Its a simple deal but I have not hooked up any of the data logging stuff yet.
Bob
Old Mar 9, 2005 | 08:03 PM
Blown5Pnt4's Avatar
holy boost batman........
sweet wideband, whats that retail for ???
Old Mar 9, 2005 | 08:41 PM
The wideband retail kit #KWB0221 (green display) is $465.00 but you need the sensor to make it all work. The sensor is part# SO20001
You can get all the info here----->
http://wideband.jaxracing.com/index.html
PS. I am not affiliated with that site or company but it is where I got mine. That wideband has been in 3 diffent vehicle's over 3 years and its been dead on the money accurate.
Bob
Old Mar 9, 2005 | 11:59 PM
RAMAIRSVT's Avatar
Bob
Living on the razors edge my friend (IMO)
Old Mar 10, 2005 | 12:39 AM
fast1's Avatar
I was thinking the same thing
Big Man's Avatar
Dear Lord!
Old Mar 10, 2005 | 01:06 AM
JeffsLightning's Avatar
Gotta love that KB You will need a built engine before the year is over... The need for power... You have an 8 lower with a 3.5" upper right? I saw 20 on mine today with a 8 lower and 3" upper... I have a little different head/cam setup though. The air was awesome...
Old Mar 10, 2005 | 07:24 AM
Jeff im running a 6lb lower (9") lower and a 3" upper
I am not worried about the motor going, if it does decide to pop I will just replace it with a built one.
Life on the edge BABY!!!!
Bob
I wont be posting again till Monday. I am heading out to Houston for the national Supra meet with a few freinds. The truck is gonna chill in the garage till I get back.
Old Mar 10, 2005 | 08:24 AM
wydopnthrtl's Avatar
This just goes to show that it really is in the tune and a adequate fuel for that tune.
Impressive.. very impressive boost numbers.
Rich
Old Mar 10, 2005 | 08:29 AM
All in the tune! I agree Rich.
I have got 60Lb injectors and twin 255lph HP feeding them, I got me some fuel.
