has anyone...?
Old Mar 8, 2005 | 10:01 AM
OD1010's Avatar
has anyone...?
i have heard that our L's have a drag limit of about 176 MPH,
1. is that true? and
2. has anyone done it??
Old Mar 8, 2005 | 10:06 AM
birdy111's Avatar
waiting for stan to chime in... I believe he's seen more than 176. but he has many aero mods and more on the way from what I understand
Old Mar 8, 2005 | 10:07 AM
evo's Avatar
evo
I think Stan has. RUSlow
Old Mar 8, 2005 | 12:44 PM
MISTERgadget's Avatar
You drag limit depends on HP, and for a stock L the drag limit is ~145.
I'm sure 176 is the drag limit for one with 150 more hp or so, and your drag limit will go even higher and higher along with HP, although hp wil increase exponentially and not in a linear way with top speed.
Old Mar 8, 2005 | 02:44 PM
OD1010's Avatar
isn't the drag limit the maximum speed something can go due to the aerodynamics? there has to be a speed where the L cuts out. however the time in which you reach that speed is a different story
Old Mar 8, 2005 | 02:49 PM
Dman25's Avatar
top speed is limited by a few things.
1. Aerodynamic Drag .... you need more hp to over come this
2. Gear Ratios .... the way they are set up makes all the difference
You know, 180mph is amazingly fast for a vehicle with a large coefficent of drag like our trucks. im sure it can be done but not much fast than that.
Old Mar 8, 2005 | 06:24 PM
Frank S's Avatar
HP can overcome drag. But to push an L past 176 MPH I would guess you would need at least 900 flywheel HP.
Old Mar 8, 2005 | 09:19 PM
birdy111's Avatar
you're talking about terminal velocity i believe. terminal velocity depends on (among other things) horsepower...
