Installed fiberglass leafs
Old Mar 5, 2005 | 05:14 PM
bglanden's Avatar
Originally posted by teamsvt2002
If you cut off one of the dunuts of your bumpstop you will have more room for your suspension to travel without bottoming out. It will give you a better ride.
My L is lower than yours i have to cut two dunuts of my bumpstop.
Thanks Teamsvt,
I was speaking to Sue from JLP last night and she recommended the same thing. I think I'm going to stick some QA-1's on the back too, I doubt the bilstien are doing anything now.
Bryan
Old Mar 5, 2005 | 10:03 PM
Casey02L's Avatar
You can also take the bump stock off, and remove the metal plate that is under it.
Mine is so low in the back that I have had to cut and bend up that flang that stick downward because the swaybar, and axle was hitting
Old Mar 5, 2005 | 10:07 PM
Casey02L's Avatar
Originally posted by JeffsLightning
You don't happen to know who made the leafs do you? I had 3 sets of Metco glass springs that could not stay together... The glass would splinter and came close to totally failing. I loved them for the weight reduction but could not trust them that something bad would happen... This is what they were doing....
Jeff; you don't think the lack of traction bars had anything to do with ithem cracking do you?
Old Mar 5, 2005 | 10:12 PM
JeffsLightning's Avatar
Yes that could have been part of the problem but at the time I was told they would handle anything I could throw at them. I had 3 sets before I gave up... I wanted to save the 75lbs + in weight but I did not want me rearend tearing out of the L either. It looks like bglanden's are made by somebody else. I might give a new set a try and God only knows I can change out those leafs in my sleep...
Old Mar 5, 2005 | 10:48 PM
bglanden's Avatar
Maybe you should give JLP's a try, but I would put some bars on there too. The only crack I saw on mine was towards the front. I think JLP charges $600 for new one's. The crack's I see in your photo's look like axle wrap to me, not real severe. I believe JLP got into 9's with the fiberglass spring's?
Best of luck
Bryan
Old Mar 5, 2005 | 11:24 PM
Casey02L's Avatar
I like the idea of saving the weight too; how do they do launching on the street/track? And how do they feel daily driving.
BTW Jeff; get the truck running good yet?
Old Mar 5, 2005 | 11:56 PM
Yes....very good...
Old Mar 6, 2005 | 12:23 AM
Casey02L's Avatar
Yes....very good...
Sweet
So, what was the problem
Old Mar 6, 2005 | 12:30 AM
Sweet
BA2400
Old Mar 6, 2005 | 10:14 AM
Casey02L's Avatar
BA2400
Was it the part or the tune
Old Mar 6, 2005 | 10:33 AM
RED 92's Avatar
Originally posted by bglanden
I was trying to minimize the amount of dirt seen!! I finally figured out what I did wrong!
Bryan
its not that dirty How dose the handling compare to the original springs ?
Old Mar 6, 2005 | 10:42 AM
bglanden's Avatar
The back end bounces around a little bit hitting bumps, I'm going to chop down the stop's, try and relocate the sway bar and buy some QA-1's. It does seem to squat a lot better during a launch.
Bryan
Old Mar 6, 2005 | 02:26 PM
reality1's Avatar
I was breaking the Glass Springs with Traction Bars.
I added the small steel leaf separated by a teflon pad to the Glass Springs.....haven't broke now in two years. Somewhat stiffer in back....better ride IMHO
Old Mar 6, 2005 | 02:55 PM
Casey02L's Avatar
You have a picture of that setup? What leafs were/are they?
