Fastener Tech Needed
Old Mar 2, 2005 | 09:56 AM
  #31
lurker's Avatar
Originally posted by SVT_KY
If you pull loose the cover on your seat belt from the bottom
(it just unclips) you will see how the shouldered bolt supports
it and allows it to rotate.
Here's where I'm at now ... the brass is 1/2 " diameter thick
walled sleeves. I intend that it would reduce the moment
at the bolt where it passes through the vertical piece (Pic 3)
You should really add another plate to the inboard end of the bolt (the bolt will need to be longer). Weld the plate to the harness bar. This will put the bolt in pure shear by eliminating any bending moments. The bolt will also be in double shear. You obviously won't be able to use the plastic cover any longer...
This will be a robust mount. Your acceleration rate in an accident may be slightly higher than a mount with some deflection but the stock belts stretch considerably anyway.
Remember Dale E. died from a compromised belt mount!
