Ported eaton/magnum s/c
Man did i start something over this post alot of mixed emotions...ok im seeing what most of the magnum s/c power level gains are....what kinds of gains are the ported blowers putting out with the modest mods..?
Originally posted by Suavy
Hey Gator, why don't you tell us how you really feel?
Can't wait to meet you and Rob this year!
Suavy
Suavy
See what happens when you go to a Jager party after work
damn, my head hurts this morning
Here is my dyno sheet.
mods are: MP built lower w/ CNC renegade racing ported heads
Apten ported blower 2.7 upper pulley
4# lower pulley
Dynatech LT headers
electric waterpump/ fan
SBTB
Crower stage 2 cams
NGK br-7ef plugs gapped at .32
That is it for the motor. I have only 3 passes on my new motor and found that my converter is junk. Hopefully this year I will have better results. I am also changing the 4# lower for a 6# lower to see if I can increase my power output.
Rich
Also I have 100 shot of nitrous, which is the higher of the two graphs.
4# lower pulley
Dynatech LT headers
SBTB
Crower stage 2 cams
Rich
Originally posted by l-menace
Rob, that is NOT entirely TRUE!
Gator, I'm not pissing people off MORE by stealing this post more.
BTW, I've had way more than 400HP off spary for yr's, r-u-drunk
AGAIN ?
Here's Fred Decker's Dyno numbers, being he's the fastest Stock Block Magnuum Powers, (11.5 @116) I think it's worth posting
stock block, stock heads, stock cams
501/591 using a 4lb lower
There's a nice write up on him in this months E-Zine HERE
I had a apten ported eaton and magnum, I do feel the magnum pulled harder than the apten, though I do not have dyno numbers from the apten port. I did make 460hp and 560lb/ft with the magnum and a custom tune, this was with a 6lb lower, my numbers were lower than most others I had seen (most ran 4lb lowers and had better numbers than me). what is even more disapointing is that my engine blew in 70 degree weather, while going 70-80mph. I had just about every bolt on. the magnum blower does have a nice sound to it, like a eaton on steroids.
