timing with 20 psi (KB) and 100 octane
Old Jan 22, 2005 | 09:09 PM
camcojb's Avatar
How much timing are you guys running on the race tune (100 octane) with about 20 psi of boost? I've heard of guys running 20-25 degrees with that much boost and race gas, but I get slight detonation going into high gear with only 15-16 degrees. Goes away with the alcohol injection on, but I'm tuning initially without it. Then again I'm running the Torco Unleaded Accelerator Concentrate in a mix that should have me at 100-102 octane.
I'm asking because I'm starting to think that this stuff may not be as good as they say. It allowed 20 degrees of timing with 16 psi of boost so it must do something.
Jody
Old Jan 22, 2005 | 10:32 PM
Calightnin's Avatar
Jody try it with race fuel instead. Also you are lugging the engine when it shifts to OD at low speeds...consider having your shift pts for OD under partial throttle moved up.
There are specific settings on your chip that deal with timing under "load". Maybe Sal will chime in.
Old Jan 22, 2005 | 10:45 PM
cal50's Avatar
I'm curiuos if you have JLP's upper intake? And is it worth that money for 1 lbs. of extra boost or stick with the stock with the heat spacers between?
Old Jan 22, 2005 | 10:53 PM
cal50's Avatar
Old Jan 22, 2005 | 10:57 PM
camcojb's Avatar
I know the timing tables. I can change anything, I run the Pro Racer SCT tuning. My main concern was with the low amount of timing I could run with what is supposed to be 100 octane. Seems this stuff may not work as advertised.
Do you know when my truck shifts into OD? I'm not having any pinging issues at all except wot.
Jody
Old Jan 22, 2005 | 10:58 PM
camcojb's Avatar
Jody
camcojb's Avatar
Jody
Old Jan 22, 2005 | 10:59 PM
camcojb's Avatar
Jody
Old Jan 22, 2005 | 11:02 PM
camcojb's Avatar
Yes I do. I think it's worth it on a high boost KB motor as the inlet on that manifold is 2-3 times larger, more air in and more boost. A milder combo may not benefit.
Jody
Old Jan 22, 2005 | 11:07 PM
JeffsLightning's Avatar
Damn trigger finger...
Old Jan 22, 2005 | 11:10 PM
camcojb's Avatar
Yeah, if I was friggen smart enough to READ THE RED WARNING ABOUT HANGING ISSUES I would have been fine! I have more trouble with this site, lol!
Jody
Old Jan 22, 2005 | 11:11 PM
camcojb's Avatar
son of a ....................... This time I did not hit submit twice! I got the famous website not responding message when I hit submit so I reloaded the page. Just can't win....
Jody
camcojb's Avatar
Jody
Old Jan 22, 2005 | 11:12 PM
camcojb's Avatar
Jody
Old Jan 22, 2005 | 11:17 PM
OMG.....ROTFLMAO....your killing me Jody...
