Oil in my Throttle Body
Old Jan 16, 2005 | 09:28 AM
  #31
RED 92's Avatar
Originally posted by max mitchell
Stating that it's on the under-hood schematic, yet it was never installed is just a simple fact, not breezing over. Since choosing to use it after testing was never mentioned, breezing over couldn't logically even apply. My intention was to provide a parts list to those who choose to use a separator. .
sorry for the misunderstanding max ......
I was only showing what is needed to design the solution that is on the factory schematic under the hood, but was never installed. It does leave the factory engineering intact and removes oil from the system.
it sounded like you were saying that since its on the underhood schematic it should be there and it removes the oil from the system. So you "breezed over" why its not there and you say it removes the oil. thats all.....Why do you choose to be negative in this thread ?
I was ONLY trying to prevent this thread from becoming another debate, as they tend to provide no sound conclusions..
well lets post sound conclusions then...do you have to agree with them to be considered sound? does this include your posts ? or just others?
I've read the plethora of opinions here ad nauseam...
........ your choice...I wouldnt read until I was nauseated.
Any members wanting an in-depth discussion of the engineering behind every oil control alternative can save time by searching RED 92s multiple posts on this topic.
thanks max ....Im blushing ...I just have opinions like yours... Lets not regulate this thread to my experiences with this issue....hang in there max, dont get mad and ruin this thread because I wanted you to clarify why you mentioned the under hood schematic.....and you did.....you implied nothing you were just stating a fact its there., cool thanks
Old Jan 16, 2005 | 01:45 PM
  #32
max mitchell's Avatar
Thanks for verifying that you misunderstood. I appreciate your clarifications, as they providing credence to each of my initial statements. Individual members will decide what, if any, oil control information they deem valuable. As usual, threads are Self-regulative. It's apparent to informed members why PCV threads become ruined and nauseating. Cool, thanks
Old Mar 20, 2005 | 12:25 AM
  #33
Bill Bell's Avatar
Max, I have read a lot of old threads and like your solution.
I looked at your parts list and totally understand everything except the parts coming out of RT side of seperation...the Cap, 1/8" NPT with 11/32 OD O-ring inside.
Hate to be so stupid...can you elaberate more on these parts and how they connect to the plenum?
Thanks a lot!
Old Mar 20, 2005 | 01:27 PM
  #34
Bill,
Not stupid ! ...ask me anything, anytime.
On the right side of the separator is ONE fitting. It's a male 1/4"NPT X 3/8" barbed fitting. The 3/8" barb slides directly into the factory black rubber adapter in the photo. When you pull BOTH ends of the factory plastic tube from this area, you'll see right where both ends of the separator assembly barb in. The "Cap: 1/8"NPT with 11/32"O.D. O-Ring inside" is simply the cap on the bottom of the bowl. Silver in the photo, it covers the valve on the bottom of the bowl. Happy retirement and Welcome from up the road.
Old Mar 20, 2005 | 03:37 PM
  #35
Bill Bell's Avatar
OHHHoooooooo! I understand!
Thanks Max for your help!
Old Mar 20, 2005 | 04:05 PM
  #36
You're Welcome !
Old Mar 20, 2005 | 05:02 PM
  #37
Master Of Pain's Avatar
Sheez guys just do this and be done with it
https://www.f150online.com/forums/sh...hreadid=188967
Old Mar 24, 2005 | 10:20 PM
  #38
Bill Bell's Avatar
Max,
I finally rounded up all of the parts today! Might mention to everyone that the filter is located in the air compressor parts at my Walmart!
One more question! Does this application change any air flow or effect any monitoring levels performed by the MAS or computer that will require adjustments?
Or, can I just install it and blow and go?
