Magnum Powers Results
I'm running a 4lb lower and the MP 2.73" upper. Charles said with the right belt and MP idler bracket, this combo should give me 17-18 lbs. Unfortunately I don't have an aftermarket boost gauge (yet) to give you any numbers. Did you install an Autometer? How tough is that to do?
Chim, I know you can tee of the under dash vac line to install in the pillar pod... which I will do when I get the other two gauges I want. For now I want to tap right under the hood and tape it up to get the same shot JDM got in their Mag demo clip. Where can I tap under the hood? Is there a vacuum fitting off the S/C somewhere?
My MP should be here this week.
Made 590rwhp 661 on a OE eaton and 75 shot with a slipping converter.
New blower, PI converter, refreshed MB and a LOTS more nitrous
Cant wait to run her this spring!
Scott
Scott
Scott
Scott
