Whipple 2.3 Dyno results
Old Dec 26, 2004 | 04:03 PM
  #31
Calightnin's Avatar
Originally posted by EZGZ
I need this broke down into simpler terms.
The big difference here is that the KB and Whipple are screw compressor's that can make more boost with less heat at lower RPM. Correct?
Is that because in addition to the above mentioned difference the compressor has more volume?
Thanks. Sorry I am so slow and drive a stock L
You are correct.
Old Dec 27, 2004 | 12:47 AM
  #32
Tim Skelton's Avatar
Originally posted by Spanky99L
. . . To my understanding the MM&FF KB test was done with a reflash done on the computer (basically a tune) and race fuel was used. The whipple test was done with NO changes besides the Whipple 2300AX unit as pictured. Stock PCM tune, Stock airbox etc. Please correct me if i am wrong. . .
Only partways.
The KB test used 100 octane fuel, but no tune/flash.
Old Dec 27, 2004 | 12:49 AM
  #33
Oh, yeah.
To all of those who still repeat the myth that a chip is required for higher boost levels,
Old Dec 27, 2004 | 01:08 PM
  #34
bacamino's Avatar
Originally posted by Tim Skelton
Oh, yeah.
Old Dec 27, 2004 | 04:05 PM
  #35
Spanky99L's Avatar
Originally posted by My Red-Rocket
So, there will not be an option to purchase the setup in the picture, with the round throttle body for those that are willing to pay?
not as it sits now. The shape of the plenum and bolt pattern where the TB connects to the plenum will change nore to a rectangular shape to accept the L throttle body setup. I'm sure if you want it THAT bad whipple might sell you the stock/prototype plenum and TB setup
SpankDog
I'll find about a GP
Will
Old Dec 27, 2004 | 04:16 PM
  #36
TheGoaT's Avatar
just please find out when the hell we can actually order one. They have been saying a couple more weeks since beginning of October.
Old Dec 27, 2004 | 05:29 PM
  #37
Spanky99L's Avatar
new updates:
All dyno numbers are in SAE format. Dyno graphs will be sent once testing is complete.
there is not a real possibility with the Group purchase
The truck used is a 2003 lightning. Ford is loaning whipple the truck. To those of you that went to sema, the red lightning that ford used as a drifting demonstration, that is the truck that whipple is currently running the 2.3 on. Here are a few differences between the whipple and the Kb:
KB is not better. There using a radial entry compressor which has approx. 10% lower VE vs. an axial entry
compressor. The rotors are not enclosed 360 deg's around the case, the top of the rotors are exposed which allows for more leakage and the rotors do not suck as much. Typically speaking, the compressors have to turn 1000-1500rpm more to equal the same airflow which requires more energy to operate and higher discharge temps and is even more dramatic when you reach
peak compressor rpms. This is fact, not opinion, we have far more knowledge in this field as we've been supercharging with axial and radial entry compressors for years, both Opcon and Lysholm, automotive and marine. Back to back test.
He also has a cast case, which on his Cobra kits, he states that it's billet which is better.
Will
Old Dec 27, 2004 | 05:41 PM
  #38
WA 2 FST's Avatar
I've got a "give me the bottom line" question. It's not meant to offend in _anyway_, or stir the pot. It's theoretical in nature, based on my understanding of forced induction (which is not professional, but honestly is probably farther along than the average shade-tree mechanic).
As it sits my truck sees 12-13psi on my aftermarket Autometer gauge. Let's just assume its accurate for argument's sake.
With no exhaust mods, the truck puts down 393rwhp/482rwtq from a stock Eaton. Yes, it has a 4# pulley, a CAI, an SCT tune and an aftermarket heat exchanger (which I'm not sure helps on the dyno when you're allowing sufficient cool-down b/w pulls).
If I pulley the Whipple to make the same boost as I'm seeing now (I realize this will necessitate a swap back to the stock lower pulley), am I correct in thinking that I'll see ~23rwhp gain over what I'm making now... given these initial tests?
I'm inclined to think so. I don't think the tune will make a big difference _assuming_ both are safe. You may be able to get a bit more aggressive with the more efficient blower at the _same_ boost level. In theory, you should be able to. However, wide variation in driving scenarios (heat/cool, high speed vs. short drag race, stop n go traffic, etc) will probably limit the "to the edge tuning" that otherwise would put up some serious #s on the dyno.
In all honesty, at the SAME boost level (albeit relatively "low" at 12-13psi compared to some of the monsters on this board), I was hoping the Whipple would show 50-60rwhp gain over the Eaton. I am SURE that at significantly higher boost levels (17+psi) the Whipple will indeed make much more significant gains over the Eaton... after all the Eaton is way past its efficiency at those levels.
Old Dec 27, 2004 | 11:33 PM
  #39
Spanky99L's Avatar
well the initial tests showed a gain of 55hp at the wheels. the stock dyno showed 351Hp and the only change being the 2300AX kit upped the Hp to 416 average over 10 runs. I would say, DO NOT TAKE THIS AS A REAL NUMBER, with your mods and changing over to a whipple you would prob be around 450-475 at the tire.
Another update:
as per dustin on the availability of the 2300's, they should be available shortly. The 3.3 being 3-5 weeks behind it. The plan on having the 3.3's in stock by the last week of Jan. They might be taking orders prior to that.
Also an adapter is being made so the lightning TB setup can be used. The setup shown in the pic of the 90mm throttle body can still be used at an additional cost.
Will
Old Dec 27, 2004 | 11:52 PM
  #40
ShockTherapy's Avatar
...Another update:
as per dustin on the availability of the 2300's, they should be available shortly...
As in, 1st-2nd week in January maybe? Oh, and will they be polished? I have to have a polished one for my truck.
Old Dec 27, 2004 | 11:57 PM
  #41
Spanky99L's Avatar
with the adapter being made instead of a whole plenum it could be very much possible. The adapter cuts down a lot of time compared to making a whole new plenum
Polished will be a $600.00 upgrade. The will come from whipple with the black krinkle finish like the works 140.
Will
Old Dec 28, 2004 | 12:22 AM
  #42
WA 2 FST's Avatar
Will
Will, I appreciate your thoughts. However, I don't think I made myself clear.
With my mods (4lb lower pulley to be more precise), I would be way over 13psi if I just swapped on a 2300. Probably pushing 18psi. I'd agree... it would be 450+rwhp easily.
I also understand that it made 55rwhp over stock on the test truck, but _most_ of that was b/c of the boost increase. In my case, I'm not going to want to increase boost.
I'm honestly trying to figure what the difference is taking XXpsi vs. XXpsi... and considering the relatively low boost level I'm running. I am probably in the minority here, but I believe its a relative topic concerning blower efficiency comparisons at a given airflow.
Old Dec 28, 2004 | 12:30 AM
  #43
Spanky99L's Avatar
yea the guesstimate of numbers was if you switched to a stock lower and kept your current mods except the 4lber and got a tune. If you kept the 4lber that would be pushing it
Will
Old Dec 28, 2004 | 12:48 AM
  #44
chimshady1's Avatar
Spanky,Is there a different internal gear ratio thats responsible for the higher boost levels?
Old Dec 28, 2004 | 01:10 AM
  #45
KUKS's Avatar
since FRPP will have whipple superchargers , will there be any chance that it will not void my warranty???? If it will void my warranty, I would have to wait 6yrs before I even think of buying any performance parts for my lightning......
