Guys, WTF is this.
Old Nov 17, 2004 | 12:00 AM
Blown347Hatch's Avatar
Originally posted by Big Man
Im running NGK TR6 plugs(or was )are those not enough? I have BR7 plugs, should I through those in?
BTW, with my ported eaton, 4lb lower, and 45 degrees i saw 17lb of boost the other night. Of course thats when I got this problem.
I am running NGK TR8-IX plugs.
Old Nov 17, 2004 | 12:13 AM
Casey02L's Avatar
http://www.autolite.com/tech/PlugTips.pdf
Old Nov 17, 2004 | 12:37 AM
Tim Skelton's Avatar
Im glad some of you guys are getting a kick out of this but I really need help with this. . .
Lighten up, big.
Zbicknog says those plugs look perfect to him. A lovely shade of green.
Old Nov 17, 2004 | 07:37 AM
SVT_KY's Avatar
really need help with this. Anybody else please chime in with
helpfull info so I can get the truck working right again.
Jeez ... People told you ... Try a colder plug. I am running
a 6 pounder with no port and use the BR7ef's ...
But most of all CHECK The A/F, foo ... Before it gets any colder around here.
Old Nov 17, 2004 | 11:10 AM
lightmup's Avatar
Originally posted by Dave02
you got algae growing in your engine?
get one of those algae eater fish at the pet store and stick it in you intake. That'll clear right up
it could be fungus........has your truck been hanging out with any skeezy imports??? you better get some penacillin fuel additive quick, otherwise you might get the oil drip
i think i just wet my pants!!!
Old Nov 17, 2004 | 11:17 AM
lightmup's Avatar
based on the info i got from all the spark plug catalogs i have at
my parts store it states "worn out" and "deterioration"
(from denso and autolite) from the colors
peace
dustin
Old Nov 17, 2004 | 01:19 PM
Big Man's Avatar
peace
dustin
Really??? Do NGK plugs get worn so soon? I have had them in for the past 10K miles.
Old Nov 17, 2004 | 01:28 PM
Don's Bolt's Avatar
That plug didn't look worn to me, but I would like to see some pics of the electrode and insulator.
The TR6 is the right plug for your mods, hell I run the same plugs and mine never turned green but my truck is pig rich.
I would get your truck on a dyno and see what the air fuel is. Without a good A/F reading all we are doing is guessing.
If you are indeed running lean changing to a colder plug won't solve your problem, it will just mask or hide it a little.
Old Nov 17, 2004 | 02:11 PM
RED 92's Avatar
Running lean was not your original problem though...green is lean or just bad fuel, did you ever hear any pinging ????
is it still running bad ?? have you put some good fuel in ...100 octane, in case it was bad fuel.
Old Nov 17, 2004 | 02:29 PM
Big Man's Avatar
Thanks for your help Don. I have been trying to get to the dyno but everytime I call I get a damn answer machine and they never call back when I leave a message. I'll keep trying though.
Yes its still doing it, idleing bad and still sterddering or missing. About the fuel, I did fill the truck up the night before the problem with BP gas. I trying to get all used up to see if that was the problem. Oh, and if you can tell me where to get 100 octane gas in Western Ky, please tell me.
Old Nov 17, 2004 | 02:49 PM
Konig's Avatar
I had some green coloration on my stockers when we pulled them...I dont think it was on the top of the plug though.....we figured it was from using injector cleaner. My truck was/is running a bit lean...
Old Nov 17, 2004 | 03:59 PM
Rob_02Lightning's Avatar
Im glad some of you guys are getting a kick out of this but I really need help with this. Anybody else please chime in with helpfull info so I can get the truck working right again.
Change Fuel Filter EVEN IF IT'S BRAND NEW
(ALL IT TAKES IS ONE TANK OF BAD GAS, HAPPEN TO ME)
Change Plugs (YES GREEN =LEAN)
I'd add a good Injector Cleaner
and get some 100 Octane
Lean = MANY POSSIBILITY'S,
Clogged Injector, Filter, Bad Fuel, Crappy Fuel, WRONG OCTANE Fuel, Tune, etc....
My Truck was only a Virgin when it Happen
All it took was one tank of fuel from Amoco
(I have since then burnt the station down)
J/K
OR AM I ??? hehehehehehehe................
Cause
Old Nov 17, 2004 | 04:11 PM
clonetek's Avatar
are TR6's or BR7's okay for a 4lb pulley & no port? It's time to change my plugs..
Old Nov 17, 2004 | 04:35 PM
brain bypass's Avatar
i have been running tr6s with my 4lber, no port for 25K, no detonation. i am changing them as soon as i get my coil pack bolts from MAD.
Old Nov 17, 2004 | 05:43 PM
wydopnthrtl's Avatar
Big Man, I'm running very similar mods / boost you seem to be. So far my denso IT-20s have looked very good.
Rich
