lowering-been reading and reading (experts come in)
Old Nov 14, 2004 | 10:43 PM
svt_2004's Avatar
AMOJOHNNY-
that looks great what is your EXACT setup, same color as my truck to!
how does it ride, i think i will go with what you have!
Old Nov 15, 2004 | 03:11 AM
kerno's Avatar
Removing the center leaf from the 2003/2004 spring pack and adding a 2 " shackle will lower the rear so that the rear bumper is about 1.5" below the rear bumper of a 1999/2002. It also improves the ride. My drop shackles have two sets of holes. Obviously, the upper holes make the truck sit lower than the lower holes. I'm running a set 1999/2000 springs, with the next to longest leaf removed and am using the lowermost holes in the shackles. I have stock 2003 front springs and the rear sits about 1/2 higher than the front. If level is what you're looking for, it's pretty darn close. I had to cut the bump stops so they're about 1 inch high. If you don't cut 'em, it will bottom out too quickly. I think that I'm about as low as I can go without having to c-notch the frame.
Old Nov 15, 2004 | 05:30 AM
AmoJohnny's Avatar
What I have installed is the 'newer' style Hotchkis TVS kit. Includes springs and swaybars. I also added the Hotchkis Bilsteins. Handling is amazing. Feels solid and tight. Just the way I want it. I believe the drop it a 2-3"(not 100% sure). If you want only the drop, you can buy the springs separately too. Let us know what you decide on.
Old Nov 15, 2004 | 09:25 AM
svt_2004's Avatar
amojohhny, i just want the springs - where can i get them?
kerno- im gonna remove a leaf and leave the shackles in, sorry to sound stupid but when i installed my shackels i used the farthest hole from the bolts to the body, is that wrong? Or am i reading what you said wrong?
thanks so much for the help guys, sorry to ask so many questions
Old Nov 15, 2004 | 10:57 AM
svt_2004's Avatar
will using a 2" rear LOWERING shackle, and using a 2" rear hanger, lower my truck 4 inches or is there more to it??
Old Nov 16, 2004 | 02:39 AM
AmoJohnny's Avatar
try this...
Lightning Force Performance, Hotchkis
Old Nov 16, 2004 | 02:47 AM
In Flames's Avatar
Here is how my 04' sits with 2" rear shackles, Hotchkis rear leaf springs, Ground Force 1" drop front springs with 1/2 a coil cut off for a total of a little over a 1 1/2" drop up front.
The truck rides just how I want it to with this setup
Old Nov 16, 2004 | 05:37 AM
svt_2004's Avatar
wow very nice pic, thanks to all that have replied, i hope my 22's dont rub after all of this!
Ill post pics when i get everything done
