Heads and cam combo?
In my never ending guest for more power I am thinking its time to get new cams and get some work on my heads. I don't want to add more boost to my setup I am already running 6 lbs of extra boost with a ported eaton on a stock block.
Who has a good deal on cam and heads combos? I want to get stage II cams and just minor work done to my heads a stage I job.
Are all stage II cams the same? (comp cams, crower, mod max)
Thanks everyone.
My current mods:
4lb lower
2lb upper
ported eaton
long tube headers with full exhaust/ no cats/ with X-pipe
sb/tb
Open element CIA
Tuned by JLP
Thanks everyone.
My current mods:
4lb lower
2lb upper
ported eaton
sb/tb
Open element CIA
Tuned by JLP
I have J.L.P ported heads and stage 2 comp cams.Its got a nice lope to the sound and feel but in my opinion i dont think it was worth the $1800 for the heads and $1200 for the cams.I know people with the same mods i got without the heads and cams and are pushing close to the same power.I hear they work well with an aftermarket blower but i havent crossed that bridge yet.
$1200 for cams?
Loosebolt has Livernois make a custom set for him for a little over 1/2 of that.
Originally posted by Grimace
From what I have read, the stock heads are not worth porting, or tryin to get more airflow out of. You would be better off buying an aftermarket set of heads, and then going to stage2 cams.
all of the aftermarket heads are just ported stockers.
We carry heads and cams assembled with thread setters for $3300. These are Brand new CNC Ported heads with a 3 angle valve job, Crower Stage 2 Cams, Ferrara Valves, Crower Springs, Manley Retainers, brand new seals, guides, rockers, lifters, sprockets, spacers, etc.... They are the heads we use on all of our Daily driven 10 sec trucks. The heads come with thread inserts for the spark plugs. For more info or if you would just like to talk more about them call me at JDM 732-780-0770.
JimIII@JDM
JimIII@JDM
JimIII@JDM
JimIII@JDM
how much power are people getting out of just cams on a stock motor with 4-6lb pulleys????
dustin
Not bashing;
why use thread inserts? why not use the new heads with 8 threads or whatever they have?
I thought tuners were using Patriot heads for porting... Guess I was wrong
dustin
dustin
J3
Most thought, "You can't be moving that much air!"
When we got my built engine in and let it warm up we reved it twice and colapsed the K&N filter.
There is 1/16" between my injector port and my intake port on my intake also.
Suavy
J.L.P. about a year and a half ago.
