Is the AF1 CAI an open element filter?
Old Nov 12, 2004 | 06:42 PM
lightning66's Avatar
Here is an AF1 slightly modified by me
Old Nov 12, 2004 | 06:52 PM
NCsvt2003L's Avatar
Funny pic Tim! What did you do, to slightly modify your AF1 intake, lightning66?
Old Nov 12, 2004 | 06:58 PM
Notice the t-clamps and the black vs the blue 4" ring and the inlet side fed by the ram air well let the pic talk for itself
Old Nov 13, 2004 | 10:12 AM
RED 92's Avatar
Originally posted by Tim Skelton
Please explain -- or better yet, prove -- why a fluid with multiple entry paths would prefer the 2" open disc at the end of the filter to the exact same material -- of which there is about 20 times more -- around the outside of cylinder the filter. Especially when the fluid is less dense (underhood heat) around the cylinder, and therefore easier to draw through. And the path of least resistance is the section of the filter closest to the base.
NO...you definitely got me....with facts, your right. you make a good argument for CAI
another fact that remains and is overlooked with "L" owners IAT datalog tests...... is, that all factory intake systems are designed to get air into the engine from outside the engine compartment......some lightning owners convince themselves (with vendor support) that this is an unnecessary design characteristic so they can slap the cone on cause it looks and sounds cool (The magic of marketing).....to each his own.
If your engine air requirements can no longer be supported by the factory intake, which draws air from outside the engine compartment and you chose to upgrade.
why would one's upgrade start with "eliminating this fundamental design" ... its hot debate ! , CAI advantages may be proven to be slight at any given condition...but,
Im leaning to the draw air from outside the engine compartment engineering crowd ....and not by driving over 35...
so whats your design for CAI Tim ? or have you decided its not going to make a big enough difference to mess with.
