Is the AF1 CAI an open element filter?
Old Nov 10, 2004 | 10:52 PM
vinnyxgunz's Avatar
just what the subject says. is the air force one cold air intake system an open element filter or not? thanks.
Old Nov 10, 2004 | 10:56 PM
Marc Carpenter's Avatar
Yes the Air Force 1 is an open element filter, and one of the best as for as I am concerned. I ran one on my Lightning and loved the performance it created in conjunction with the other mods I had.
Old Nov 11, 2004 | 09:47 AM
RED 92's Avatar
Re: Is the AF1 CAI an open element filter?
yes its open ended and 15 inches so it reaches all the way to the fender opening. It comes with a hard rubber boot to connect the filter end to the fender.
I enclosed my AFO to keep under hood air out.
Old Nov 11, 2004 | 10:24 AM
Tim Skelton's Avatar
Is a "cold air intake" an "open filter?"
Think about that question for a moment.
Old Nov 11, 2004 | 10:48 AM
ZEM'S04 L's Avatar
If a tree falls in the forest and there is nobody around
does it make a sound?
Old Nov 11, 2004 | 10:58 AM
Grimace's Avatar
If a man speaks out loud in the woods, and a woman isn't around to tell him he is wrong, is he?
Old Nov 11, 2004 | 11:22 AM
ZEM'S04 L's Avatar
HELL NO!! A man is never wrong!!
Old Nov 11, 2004 | 11:29 AM
KCinAZ's Avatar
If a tree falls in the forest and crushes a mime, does he make a sound?
Old Nov 11, 2004 | 11:32 AM
FunFord's Avatar
Registered User
Those are so funny
Old Nov 11, 2004 | 11:34 AM
RED 92's Avatar
YES GRASSHOPPER...., you not catch on yet...
if the open filter has an open end and ...said open end attaches to a cold air source, fender, then it is deemed Cold Air Induction by its maker.......so, that frigid air from the open end makes all the difference in the world when you compare it to a plain ole open filter with no open end which only gets air from blazing hot under hood......
Old Nov 11, 2004 | 11:48 AM
Originally posted by RED 92
. . . so, that frigid air from the open end makes all the difference in the world when you compare it to a plain ole open filter with no open end which only gets air from blazing hot under hood......
Excuse me for a second . . . need to do something . . .
Please explain -- or better yet, prove -- why a fluid with multiple entry paths would prefer the 2" open disc at the end of the filter to the exact same material -- of which there is about 20 times more -- around the outside of cylinder the filter. Especially when the fluid is less dense (underhood heat) around the cylinder, and therefore easier to draw through. And the path of least resistance is the section of the filter closest to the base.
The magic of marketing. Sigh.
Old Nov 11, 2004 | 11:51 AM
Grimace's Avatar
It shure is purdy though.
Old Nov 11, 2004 | 12:12 PM
RED 92's Avatar
the open end provides a desirable air flow pattern that denser air forces out the hot air as it moves throught the filter with the small ram affect.
Tim, on the surface your statement is logical in theory...aka... same material, larger surface area exposed to heat....CR vs airflow is what is important, increase in CR will momentarily increase vacuum inside the filter since the ratio of the temp/volumes being compared has changed. Effective vacuum after TDC - V1/V2.
V1 = chamber volume.
V2 = intake port, manifold leg, plenum, ram air through the filter.
this simple equation shows compression vs airflow improvement with an open ended filter.
check the link that supports my findings ........Marketing hype my ars !!!
link to study
Old Nov 12, 2004 | 12:24 AM
. . . check the link that supports my findings ........Marketing hype my ars !!!
link to study
Ya got me.
Old Nov 12, 2004 | 01:13 AM
Grimace's Avatar
Nice. That is a great pic of the monkey.
