Moroso pan.
Old Nov 9, 2004 | 07:59 PM
goatheady's Avatar
I'd like to get one too. Does anyone know the part number for it? And do you
need the 4X4 filter, or just the stock one?
The Ghead
Old Nov 9, 2004 | 08:08 PM
SVTJAY's Avatar
Use Motorcraft Filter Part No. FT113
Moroso Part # 42050
Summit Part # MOR-42050
Jegs Part #710-42050
Old Nov 9, 2004 | 09:59 PM
goatheady's Avatar
Thanks Jay.
The Ghead
Old Nov 10, 2004 | 12:15 AM
FunFord's Avatar
Registered User
Where are you all getting your Moroso pans from, I cant find them?
Old Nov 10, 2004 | 04:38 AM
SVTJAY's Avatar
did you check Summitracing.com and Jegs.com?
Old Nov 10, 2004 | 08:25 AM
JeffsLightning's Avatar
Moroso Transmission Pans from Jegs
View larger image
Product images may differ from actual product appearance.
As the undisputed leader in oil pan technology, Moroso has turned its attention to the design and manufacturing of premium quality Transmission Pans. Unlike heavier cast versions offered by others, Moroso Transmission pans are fully fabricated entirely from lightweight aluminum and feature a one-piece billet rail to ensure leak free sealing. Precise CNC manufacturing and TIG welding prevent distortion for a perfect fit every time. Pans with extended depths (see diagrams for dimensions) reduce temperature and improve oil control during acceleration and braking. We've included filter spacers on extended depth versions where needed. All Moroso Transmission pans include dual fittings(except 710-42050) with magnetic drain plugs and pan mounting hardware consisting of steel studs and convenience. Pan gaskets are not included and must be purchased separately
710-42050 Transmission Pan, Ford Lightning E40D/4R100, 3.642 inch depth. | View Product $159.99
Old Nov 10, 2004 | 08:53 AM
lightning66's Avatar
That is a nice looking pan, I wish I can get my TIG welds that uniform.
For $159, that is not to bad. Any one want a 4x4 pan
Old Nov 10, 2004 | 10:02 AM
Grimace's Avatar
You can make your welds look that good. All you have to do is become a machine.
Old Nov 10, 2004 | 11:13 AM
FunFord's Avatar
Registered User
Will the factory gasket work, or do I need one from Moroso.
Old Nov 10, 2004 | 01:11 PM
Factory....it's reusable...
Old Nov 10, 2004 | 03:13 PM
FunFord's Avatar
Registered User
Thanks Jeff, for all your help.
