Moroso pan.
Old Nov 8, 2004 | 11:32 PM
FunFord's Avatar
Registered User
Moroso pan.
I am interested in a new trans pan. I like the Moroso one because it does'nt hang down further than the stock one, and it holds 3 extra quarts. Without the cooling fins will it get hot enough while racing to worry about, or should I get one with cooling fins like the FRPP or the B&M pan?
Old Nov 9, 2004 | 12:03 AM
superfords's Avatar
plenty of people use the stock fan and it doesn't have any fins.
adding the additional 3 quarts will help reduce fluid temps.
Old Nov 9, 2004 | 12:14 AM
FunFord's Avatar
Registered User
But the Moroso pan is thicker, do you think it will hold in heat more than the others?
Old Nov 9, 2004 | 01:17 AM
Tim Skelton's Avatar
It's SOLID aluminum, though, whereas the others are porous sand cast.
I can't say for sure, but I would bet that it is as effective as a finned cast pan.
Old Nov 9, 2004 | 02:06 AM
Grimace's Avatar
Anything aluminum will dissapate heat better than a steel pan. Steel hold heat quite a bit more than aluminum.
Old Nov 9, 2004 | 08:53 AM
FunFord's Avatar
Registered User
Thank you everyone! Looks like I will prob. be getting the Moroso one soon, I will make a post about the install and how I like it.
Old Nov 9, 2004 | 10:25 AM
JeffsLightning's Avatar
I would get the Moroso
Old Nov 9, 2004 | 10:56 AM
Grimace's Avatar
That is a nice looking pan. Too bad I just bought the 4x4 pan.
Old Nov 9, 2004 | 11:15 AM
fastfordf150's Avatar
That pan is awesome. If I hadn't already purchased a finned aluminum pan (MAC/B&M/FRPP), I would definitely opt for the Moroso.
Old Nov 9, 2004 | 11:34 AM
moses Black 01''s Avatar
Where can i purchase one of the moroso pans without spending my life savings, or is that possible
Old Nov 9, 2004 | 12:18 PM
TrackBeast's Avatar
Does the Moroso pan really have the same depth as the stock one? I thought it really hung lower.
Your best bet is to add another cooler if you want to reduce tranny temps.
TB
Old Nov 9, 2004 | 12:36 PM
RhinoSlug's Avatar
The moroso pan is expensive, isnt it?
Old Nov 9, 2004 | 01:24 PM
FunFord's Avatar
Registered User
TB
Thats what someone told me.
Old Nov 9, 2004 | 02:05 PM
It is as low as stock unlike the Ford 4x4 pan. The drain plug is to the side to avoid hitting anything. Especially nice for lowered vehicles. It holds 3 to 4 quarts more fluid..
Old Nov 9, 2004 | 02:11 PM
SVTJAY's Avatar
For those of you who are worried about clearance issues. Here are a couple shots of it installed. You can see that it barely hangs lower then the frame cross member. It is slightly deeper then the stock pan, but doesn't hang near as low as the 4x4 pan.
