Oh my Boost--stock apten
Originally posted by halflife
MOds currently
Apten pnp blower and upper intake
JLp intake
bassani catback
160 thermo
Plus I just cleaned my intercooler and IAC if that makes any difference.
Plugs gapped at .35
MOds currently
JLp intake
bassani catback
160 thermo
Plugs gapped at .35
halflife, do you have a built motor ....or a stock motor?
Originally posted by TrackBeast
Did I read this right? With stock pullies, program and just a filter, and porting you damaged the plugs???
I really would have thought that you would still be really safe.
TB
TB
1.Plugs fowled from just breaking in the new motor
2. there were bad from the old motor
3. detonation
I am going to pull all the plugs once I get replacements to check them out. I will update all with my findings.
Halflife,
It would be really interesting to check your A/F currently. My theory is that on a near stock engine, the computer should be able to compensate for the ported blower. So you shouldn't be lean and I would be very surprised if you were. But, anything is possible.
TB
TB
Halflife,
TB
Halflife,
TB
halflife, TrackBeast
I have an 01 with stock pulleys, Apten blower porting, home ported upper, and modified stock air cleaner with Airaid drop in. I also have a wide band. I had to get a chip because with the Apten porting my A/F was almost 13/1. My stock guage also went over somewhere close to 9 oclock with the stock pulleys, I could not believe it.
TB
