methanol
Old Sep 2, 2004 | 08:58 PM
bglanden's Avatar
methanol
Has anyone tried using methanol as a primary fuel with the lightnings? We used to use it on a dirt modified,quite a few years ago, made a couple more horsepower and kept the engine cooler with jetting. Basically we controlled the temperature with the jetting. I seem to remember using about 3x more fuel with the alcohol?? But this was all with a carbuerator!
Just food for thought. I doubt our injectors could spray the amount of fuel we would need.? Xuck Bin Laden and the arab peninsula!
By the way, we could stop exporting all of our corn and make racing fuel!
Old Sep 2, 2004 | 09:03 PM
EZGZ's Avatar
It does run cooler and solves a lot of problems but creates just as many as you said.
I suppose you could get biger injectors and a pump but it would be like having a 8 gallon fuel tank and be just for racing.
Old Sep 2, 2004 | 09:19 PM
bglanden's Avatar
Yeah but if you get a beater for every day driving I think It's something feasible?? Just not sure how to do it??
Old Sep 2, 2004 | 09:48 PM
yysenhimer's Avatar
Our fuel systems are not designed for methanol which is highly corrosive.
Old Sep 3, 2004 | 10:11 AM
Silver-Bolt's Avatar
What you need to look at is methanol/water injection. Do a web search under "Aquamist injection". It is a motor saver. Completely computerized system that injects meth into the combustion chamber. Can be programed to inject at boost pressure, rpm, etc. More H/P and no knock.
Old Sep 3, 2004 | 10:24 AM
yysenhimer's Avatar
The Snow Performance kit is a better kit IMO, but I saw a loss in performance above 3500 RPM with what little testing I did on the L. The place I went for a dyno tune didn't want to spend the extra time to dig deeper and change things around. My A/F was in the 10's but I was running race gas with it at the time. The supposed gains come out of using pump gas with added boost and timing. I never got back there to do any more testing because I simply couldn't afford the time and money they were charging. Needless to say I was pissed off when I left there with like a $600 bill and basically the same tunes I had when I got there. I may do more testing at a later date though.
Old Sep 3, 2004 | 11:56 AM
hslightnin's Avatar
Re: methanol
your still gona have to change your oil like every 250 miles
Old Sep 3, 2004 | 12:49 PM
bglanden's Avatar
Re: Re: methanol
Yeah, I forgot about that, we had to change it after every race! But during tear down everything was pristine.
Old Sep 3, 2004 | 01:42 PM
chiz's Avatar
alot of mustang guys run the snowperformance water/meth injection.....but they either run straight water, or windshield wiper fluid, witch is a mix of water/meth
